fuel problem
Old Dec 19, 2011 | 09:25 PM
dino360's Avatar
dino360
fuel problem
My 91 Ranger with a 4.0 acts like it's out of gas any time it sits for an hour or so. Try to start it in the morning I gotta crank and crank as if it needs to be primed with fuel. Get to work and in the afternoon same problem. If I'm running around town, it starts up fine every time as long as it hasn't sat very long. Any suggestions?
Old Dec 26, 2011 | 10:49 AM
subford's Avatar
subford
Turn the key on and then off three times before cranking it.
Old Dec 27, 2011 | 03:45 AM
dino360's Avatar
dino360
I had tried turning the key off and on 3 or 4 times with no luck. I was also experiencing a slight rough idle and missing under hard accleration on the highway. I had the Fuel pump replaced a few months back thinking the fuel pump was causing the idle/accleration problems and just last week replaced the fuel filter, fuel pressure regulator, and spark plugs to try and remedy the starting problem which started about a month ago. All spark plugs looked pretty clean with no apparent signs of rich mixture. The truck now runs and idles smoother and the missing under accleration problem is fixed. It is still taking a long time to start if anyone has any ideas.
Old Dec 27, 2011 | 04:02 AM
dino360's Avatar
dino360
McNice
Mar 14, 2017 06:52 PM
Klr44
May 13, 2014 10:36 AM
Kirtgan
Modular V8 (4.6L, 5.4L)
Dec 1, 2010 01:45 PM
stangbanger
May 9, 2009 05:33 PM
735.0Short
Nov 23, 2006 05:35 PM
