Fuel problems
Old Nov 30, 2010 | 05:30 PM
Kirtgan's Avatar
Kirtgan
Fuel problems
Please Help.
I have a 5.4 2001 Excursion, no mods. It was bogging down occasionally at freeway speed and idle was slightly rough. I replaced the spark plugs and boots, the problem disappeared. A few weeks later it leaves my wife stranded at the store.
It cranked fine, but would not fire. I got it home and pulled the fuel filter and it runs fine. A few days later, it won't start again. I was not getting any gas out of the pressure valve on the fuel rail. I had a second filter on hand and switched it again. It fires up, but is hard to start. Have to tap the gas pedal to get it to fire. Runs great once its going.
Could it be anything other than the fuel pump at this point? I don't want to drop the tank if there might be something simpler to try.
Old Nov 30, 2010 | 11:15 PM
Moto Mel's Avatar
Moto Mel
That sounds like a bad fuel pump. Do you hear the pump start to run when you turn the key on? Also you can check the fuel pump fuses and relays.
Old Dec 1, 2010 | 10:17 AM
Kirtgan's Avatar
Kirtgan
I can hear the pump run, I think but pressure seems hit and miss
Old Dec 1, 2010 | 01:37 PM
Moto Mel's Avatar
Moto Mel
Check your fuel pressure several times while it is running, you may have a bad pressure regulator.
Old Dec 1, 2010 | 01:45 PM
Kirtgan's Avatar
Kirtgan
How will I know its the regulator and not the pump?
