Quick Question
Old Dec 19, 2011 | 08:19 PM
zombiefied 247's Avatar
zombiefied 247
Quick Question
If i take a few leafs out of the front end to lower will it make the ride rough and make it handle like crap?
Old Dec 19, 2011 | 08:23 PM
52 Merc's Avatar
52 Merc
There's not that many leaves in the front to begin with, so taking out a couple will make a big difference. With less support, the truck will definitely drop. It will also leave you with a softer, bouncier ride and could very well handle like crap, being more 'springy' and having a lot more body roll. Without knowing how worn or weak your springs are before modifying, it's hard to say what will happen after you do. It'll surely be a trial and error thing.
Old Dec 20, 2011 | 01:41 PM
tinman52's Avatar
tinman52
Welder User
I removed 2 or 3 and de-arched the rest......It rides better, IMO. I had to use shorter shocks. It also has more body roll.....not horrible. I plan to install a sway bar to help it corner better.
Old Dec 20, 2011 | 10:27 PM
zombiefied 247
Hi tinman what do you mean by de arch?????
Old Dec 20, 2011 | 11:06 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Don't take too many leaves out. You can really increase your bump steer if you lower it too much. A good rule of thumb is to try and keep the drag link parallel to the ground. Of course you can modify the drag link angle slightly by heating and tweaking the steering arm.
Also, in your quest for lowering the truck don't get rid of the bump stops. I forgot to reinstall my bump stops and ended up breaking my main leaf one night when driving the truck kind of hard.
Bobby
Old Dec 23, 2011 | 10:57 PM
zombiefied 247
thanks for the info guys I appreciate the input
shelby67air
Jan 27, 2016 01:34 PM
icentropy
Jun 26, 2014 01:37 AM
ljhedrick
Jan 18, 2012 12:13 PM
Blue50F-1
13
Sep 11, 2006 02:53 PM
tym2clm
Dec 14, 2004 01:22 PM
