cam sensor??
Old Dec 19, 2011 | 07:52 PM
crescentmoon96's Avatar
crescentmoon96
cam sensor??
i have 96 f350 7.3 with 115000 miles the other day i was driving and it started sputtering and seemed like it was running out of fuel but the tank is full the filter is clean and the bowl has fuel and i just replaced the whole fuel housing in the spring, it intermittently runs like **** and when it does the check engine light comes on, i had my friend plug in a reader but no codes come up, so under his suggestion i replaced the cam sensor in hopes that was it and after i replaced it i drove it around for an hour and it seemed fine, but i just drove it again and its happening all over. so any suggestions thoughts would be greatly appreciated i think im gonna go slam my head into the fender a few more times to get out the frustration
Old Dec 19, 2011 | 08:05 PM
fordpride's Avatar
fordpride
What kind of scanner ?
If the CEL came on then you have a code.
fordpride's Avatar
fordpride
Welcome to FTE !
Old Dec 19, 2011 | 08:08 PM
crescentmoon96
thank you and it was a MAC scanner looked like a really expensive piece of technology but i have no idea i still buy compact discs if anyone knows what those are anymore
Old Dec 19, 2011 | 08:17 PM
Action4478's Avatar
Action4478
Most likely a burned under valve cover harness ...You need to do a buzz test .. the code should be 1316 ...
Old Dec 19, 2011 | 08:18 PM
crescentmoon96
that sounds like a lot of fun...whats involved with that?
Old Dec 19, 2011 | 08:24 PM
BuckHammer's Avatar
BuckHammer
Nevermind.
Listen to the other guys on this subject.
Old Dec 19, 2011 | 08:27 PM
crescentmoon96
what i should i use to try to get the right code? and thank you guys for the immediate responses
Action4478's Avatar
Action4478
See if your scanner can run a buzz test ...
Old Dec 19, 2011 | 08:29 PM
crescentmoon96
sorry no idea what a buzz test wish i knew more stuff...im not a mechanic i just play one on tv
Old Dec 19, 2011 | 08:30 PM
Action4478's Avatar
Action4478
I'm not familiar with a Mac .. scroll through it ....
Old Dec 19, 2011 | 08:33 PM
BuckHammer's Avatar
BuckHammer
Nevermind.
Old Dec 19, 2011 | 08:37 PM
Action4478's Avatar
Action4478
OOps ...............
Old Dec 19, 2011 | 08:50 PM
BuckHammer's Avatar
BuckHammer
Nevermind.
Old Dec 19, 2011 | 08:51 PM
Action4478's Avatar
Action4478
How about posting some info on the scanner you are using .. we can tell you if its capable of doing a buzz test ..
