Sponsored by: Real Truck
2001 F250 Will not shift into reverse
Old Dec 19, 2011 | 05:44 PM
RobertF250's Avatar
RobertF250
My 2001 F250 4X4 with V8 gas engine and automatic transmission will not shift into reverse gear. Actually it kills the engine after a few seconds in reverse. The forward gears seem fine. I checked the fluid and it is a little low and I also noticed a few small fluid spots on the ground, is that enough to keep it from going into reverse. I am also confused whether I can top it off with Mercon V and then drive it to my local garage even though the dipstick says Mercon. Where is the most likely place that the fluid will leak from. It looks like it is dripping from somewhere directly above the front axle bracket on the passanger side. It was 19 degrees so I didn't feel like climbing underneath the truck today, so any help would be appreciated.
I assume I add the ATF into the dip-stick tube? Thanks for your assistance.
Old Dec 19, 2011 | 06:00 PM
PA-Mark's Avatar
PA-Mark
if its leaking from the front of the truck, its one of the transmission lines, fittings, or oil cooler. this is where they are and where the lines run.
trans coolers dont fail that often, but lines will tend to develop leaks over time, so i would check there.
DEPENDING ON!!! how far away your service shop is, you can drive it the way it is to the shop. If its only a bit low, no worries, but if a quart or more, then i would add some.
Now as far as stalling in reverse, this stumps me. I have heard of stalling in a forward gear caused by a problem with the converter lock up circut shorting, but I cant see this happening in reverse... Im not a trans guru, so i cant say that its not the problem, but it dosnt seem possible to me...
anyways hope this helped, Mark
BTW, keep us posted as to what it ends up being... im interested in this one.
Old Dec 19, 2011 | 08:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's actually MORE likely to stall in reverse than drive when the torque converter clutch is on when it shouldn't be. Low fluid, loose/missing internal filter, worn pump, worn seals, stuck valve, a bad solenoid, or a bad torque converter can cause this.
Old Dec 21, 2011 | 04:22 PM
RobertF250's Avatar
RobertF250
Red face Thanks, those darn steel lines!
Thanks guys! the problem was the steel transmission fluid lines, they had rusted through where there is a bracket beneath the radiator. The repair shop also had to replace the radiator as well. They said that the lines and connectors were so corroded that the radiator connection threads were damaged. I cant believe the tank is made out of plastic.
Mark you were correct the reverse gear problem was caused by the low fluid. It was scarry thinking that I might have damaged the transmission. I added a quart and was able to back the truck out of the driveway and get it to the shop. I appreciate this website for the members advice in helping me to keep my truck running. I
Old Dec 21, 2011 | 07:19 PM
PA-Mark's Avatar
PA-Mark
Glad to help, thanks for getting back and shareing the results with us. Sorry for the radiator that sucks brotha.
The other, Mark
KAT_Ayanami
Mar 8, 2022 06:04 PM
Dam pile
51
Apr 10, 2016 01:02 PM
AMG-SM
May 16, 2013 10:25 PM
chrison600
Oct 13, 2012 12:56 PM
yellow72f100
Jun 3, 2006 08:52 PM
