ZF5 whining
Old Dec 19, 2011 | 10:24 AM
79OldBone's Avatar
79OldBone
ZF5 whining
Hey all, so I was pulling my jeep to an event yesterday and about 30 minutes away from home the trany started whining. So I pulled over and checked the fluid and it took a little over half a quart but that didnt seam to be enough to be running dry or anything? It does it in every gear except 4th. It goes away with the clutch in and in neutral with the clutch out so I'm almost 100% positive its not the throwout bearing which IS squeaking. That is brand new so that kind of pisses me off.
So are the bearings cooked? Or is there something I can try to help get some more life in this thing since I JUST did the 5spd swap and this was the 1st tow with it. It doesnt sound like its the transfer because the noise is too far forwards.
If it does need a rebuild who has the best and cheapest kits? I've helped rebuild a jeep manual before so I cant imagine this is much different. Just bigger everything?
Old Dec 21, 2011 | 10:26 AM
79OldBone's Avatar
79OldBone
Some help anyone? Any 1 bearing this sounds like it could be? Though replacing all is probably a good idea.
Anyone have a good writeup of how to do the rebuild? Also anyone know of a good place to get a rebuild kit?
Old Dec 21, 2011 | 12:19 PM
Talyn's Avatar
Talyn
do you feel vibrations in the shifter or in the 4wd shifter?
Drain fluid and pull PTO covers and inspect inside.
That will give you a good idea what's going on inside if there are some issues.
Let the oil sit a few days in a bucket and pour it out slowly, you'll find any junk sitting on the bottom of the bucket.
Old Dec 21, 2011 | 12:42 PM
79OldBone's Avatar
79OldBone
alright thanks! Well that truck has had a vib that i've been trying to hunt down but it had it before the 5spd swap. New wheel bearings and ball joints. So maybe the ttb bushings but I'm doing a D60 conversion soon so I dont want to put money in the 50. So besides that vibration it normally has the shifters are pretty steady. That was one of the first things I checked when it started to make noises. I also changed gears in the transfer.
The weirdest part is it goes away in 4th gear. When I downshift and match rpms you can hear the whining start as it goes into the gear even with the clutch in it starts a little then goes away once its in gear until you let the clutch out.
Old Dec 21, 2011 | 02:23 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Heres a bump for ya. Anyone know of rebuild kits?
Old Dec 21, 2011 | 02:36 PM
DIYMechanic's Avatar
DIYMechanic
I don't know anything about the rebuild kits, but my Google-fu is strong today. Here is a link to a recent thread about the same topic.
https://www.ford-trucks.com/forums/1...some-info.html
Check out Page 2, post 22. RRranch just rebuilt his own trans this summer and he says there where he got the parts he used (Competition Trans in California, I think). Also, there is a link in the first page to a manual of sorts that shows exploded views and has a parts list which includes part numbers for the S421, which I believe you have if your truck is a 95.
There is another link there (on page 1 I think) to Fishmanndotcom's rebuild thread as well. Plenty there to read. That should keep you surfing for a while!
Old Dec 21, 2011 | 02:42 PM
79OldBone's Avatar
79OldBone
Thanks! I did some quick skimming on google as well.
The ZF5 came out of a 91 IDI powerstroke. So not sure which model that makes the trany?
Old Dec 21, 2011 | 02:46 PM
Oldsmoky92's Avatar
Oldsmoky92
Its the 42 model i would say.
Old Dec 21, 2011 | 02:47 PM
DIYMechanic
That would be a S42 then. That manual should be correct. There were some different parts in the S47 but I think it was only in the '96 and '97 trucks.
Old Dec 21, 2011 | 02:54 PM
79OldBone's Avatar
79OldBone
Cool thanks! What exactly is the difference between the two? Lower first gear? Better O/D? Different gearing all together?
Old Dec 21, 2011 | 08:54 PM
DIYMechanic
I can't say for sure, but I believe the gearing is the same, but some of the internals of the 47 are beefed up and allow it to handle a bit more torque without issues. Maybe the main bearings on the input shaft? I don't know for sure.
Old Dec 21, 2011 | 10:24 PM
bad12jr's Avatar
bad12jr
The s42 I just put in mine is a close ratio and the gear roll over is horrible and whines slightly. It is a fresh rebuild and amsoil syn
Atf
Old Dec 22, 2011 | 12:38 AM
BuckHammer's Avatar
BuckHammer
My gear rollover at idle in neutral is pretty bad, but keep in mind that I don't have the boots fastened down on either shifter, lol.
Old Dec 22, 2011 | 11:07 AM
madpogue's Avatar
madpogue
^^^^ Now that you mention it, the OP's issue MIGHT be related to the shifter boot. At least in part. Happened to us, where we noticed more gear noise in some gears than others. Finally realized it was based on the position of the shifter, which pulled the boot out of place when it was forward (or was it back, I don't remember). So sometimes, when the noise changes with the gear, it's not internal to the tranny, but instead it's the boot moving in and out of position. That stupid bezel/frame can crack if you so much as sneeze on it.
Beyond that, if the OP doesn't know the age or condition (or type) of fluid in the tranny now, a drain and refill would be in order. ZF REQUIRES synthetic. There's even been some talk about overfilling by 1/2-1 qt by filling from the shifter.
Old Dec 22, 2011 | 11:38 AM
79OldBone's Avatar
79OldBone
Nah I checked that as welll. This was loud enough when it first started that I could hear it over my stacks at 2200rpms on the interstate, the radio on and 3 of us talking haha
