Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
ABS Light, 4x4 Light
Old Dec 19, 2011 | 04:51 AM
jbtecnico1's Avatar
jbtecnico1
2005 Escape, XLT, 4x4, 3.0L
Adding to other threads here...
ABS light on, 4x4 light flashes several times per minute.
Code B1234 (per Auto Zone), "no signal from right front"
Right front ABS ring broken but still on hub, $14.99 at A-Z...
Will report back on replacement task...will DIY...
Jim
Old Dec 19, 2011 | 07:58 PM
rickfar's Avatar
rickfar
The dreaded tone ring failure been there done that, drivers side i replaced whole cv shaft which comes with tone ring installed got axle at advance with 20% off for 55.00 . Pass side i just did ring bought at dealer it was like 5 bucks as i didnt want to mess with that side from my reading on the forums it is a common failure......
Old Dec 19, 2011 | 10:10 PM
5_labsownus's Avatar
5_labsownus
spread RTV on the tone ring ledge and place a piece of paper about 1/2 inch wide and 2 inches long on the RTV then a little more on top of the paper and then slide the tone ring in place. I have one that I did 3-4 years ago or about 50K miles and the other last year. So far I have never had to "re-fix" them.
Rod
Old Dec 20, 2011 | 06:47 AM
jbtecnico1's Avatar
jbtecnico1
Thanks for the feedback...I considered RTV too but prefer to go with a new ring...will have the strut off as well for replacement so will go with new ring...
Old Dec 25, 2011 | 11:58 AM
jbtecnico1's Avatar
jbtecnico1
New ABS tone ring installed, passenger side, easy. Cleaned up the hub with a stiff wire brush, used a little white lith grease to help start the ring, then seated in place with light hammer and punch tool...would be easier with same ID/OD "driver" to tap ring all around to get it on the hub...
Escapeartists
Apr 3, 2017 07:51 PM
EMC V10 X
Jun 10, 2012 08:31 PM
golf_luvr24
Apr 28, 2012 02:57 PM
Branny08
Apr 2, 2012 07:02 PM
adamsrancho
Oct 31, 2011 04:18 AM
