2005 Escape ABS light and 4x4 light
My ABS light is on and the 4X4 light flashes about 8 times every few minutes. I thought this would be from a cracked tone ring on teh drive axle, I put the truck up on my floor jack and I did find a cracked tome ring on passenger side. Whoever has the truck used silicone to put the broken tone ring back on. In any event I replaced the drive axle with a new OEM with new tone ring. Drives like a charm but ABS and 4X4 light still on and flashing. It is AWd Is there a tone ring on the drive shaft ? Any ideas would be appreciated
AWD Light or Sensor Or?
Have a 2006 Mariner AWD with 154,000 miles. Been a great vehicle. Just replaced the rear differential that was starting to howl badly. Bought used rear diff and the "donor" vehicle was a 2005 Mazda Tribute with 65,000 miles. Installation was good mechanically. Vehicle drives fine and the noise is gone, but AWD light blinks on and off periodically and dash readout says "service system". I do push the reset button and it readout clears on the dash until I turn the vehicle off and start it up again. Crawled underneath to check electronic connection at top of differential. Seems connected.
Anyone had any experience with this?
Thanks,
Ron
Thanks,
Ron
Yes, dealer said they had reset the code. Also said that there was a non-serviceable part located inside the rear diff and the entire rear diff had to be replaced??? Not sure of that one….Was wondering if there was something wrong with electrical connection at the top of the diff? I have disconnected and reconnected it several times. Light still comes on. Thinking that this electrical connection would be something that is a provides a connection to/from a sensor for the front wheel slipping to engage the awd system to the rear. Still wondering what to look for…. any thoughts are always appreciated and fun to troubleshoot.
