Modular V10 (6.8l)
Drain plug thread size?
Old Dec 18, 2011 | 08:21 PM
kas83's Avatar
kas83
Went to do the 1st oil change on my 2000 V10 tonight, only to find several threads missing from the drain bolt. I've got to pick up a new bolt in the morning. Hoping I can just chase the threads to clean them up, and install the new one. I wanna say it's around 9/16 diameter, but thinking it would be metric. Thanks in advance.
Old Dec 18, 2011 | 09:01 PM
dkf's Avatar
dkf
I never measured my drain plug for diameter or pitch. According to Rock Auto the thread size is M14x1.5 and 14mm = .551" in diameter and 1.5mm = .060" for the pitch.(between 16-17 threads per inch) You can take a small ruler and double check the pitch. There should be about 1/16" from thread crest to crest.(crest is point at the largest diameter)
http://www.rockauto.com/catalog/moreinfo.php?pk=1261333
Old Dec 18, 2011 | 09:51 PM
kas83's Avatar
kas83
That sounds right to me. Looks like I'll have to grab a metric tap from a buddy and hope for the best.
Old Dec 20, 2011 | 01:15 AM
kas83's Avatar
kas83
14-1.50 was the ticket. Took it nice n slow, worked fine. One thing I noticed was the crazy amount of flex the pan had while putting the tap or bolt it. Will have to look into that once it warms up.
mikeyanxu
2015 - 2020 F150
Aug 14, 2019 09:57 AM
BII Plow Truck
Oct 26, 2017 07:14 PM
crazy96863
Feb 22, 2016 08:15 AM
SaikotikGunman
21
Jan 10, 2010 07:40 PM
DeathStar
Aug 10, 2004 10:42 AM
