Sponsored by: Real Truck
Electrical Issues
Old Dec 18, 2011 | 10:18 AM
coachdennis's Avatar
coachdennis
Electrical Issues
99 F350 Super Duty 7.3 Auto Trans. 150K miles.
Started having intermit problems at 100K.
IDM Module failed replaced, torque converter started rattling replaced, then horn started going off removed fuse for horn.
Now intermit ABS issues where left or right front caliper mainly the left does not want to release unless you turn off the key switch?
Also, parking lights and dash light fuse #8 keeps blowing?
Any ideas? Thanks
Old Dec 18, 2011 | 10:56 AM
PA-Mark's Avatar
PA-Mark
yeeesh! not fun
Ok i have delt with this one a few times. not on superdutys so I cant give you a magic answer of Hea its this right here.
But this is most likely the issue, Some where in all your wire harnesses, there is a short that is most likely slowly rubbing through your harness.
It will most likely be in an area that a harness that runs through a grometed hole in the firewall.
A few times, a harness tie broke and this let the harness move from its secure location to a spot where it was being rubbed by other mechanical things ment to move through the engine bay like a steering wheel shaft.
So the bottom line is you need to search for some rubbed raw harnesses somewhere. I cant say for sure but I would bet money this is your problem.
Remember these rules, Something electrical not working... you have an open.
something blowing fuses, short to ground.
something working when not asked, short to hot.
Hope this helps, Mark
Old Dec 18, 2011 | 02:49 PM
dchamberlain's Avatar
dchamberlain
Pull the fuse box down from under the dash right above the drivers left leg. There should be 4 bolts holding it in and it should just pull right out.
Look for signs of water and/or corrosion. There was a problem with some early model SD's where the windshield wasn't sealed properly and rain water got down into the fuse panel and GEM module.
Old Dec 22, 2011 | 12:50 PM
coachdennis
FIX
Talk about a headache....
Over the past week I have disconnected all the running lights, trailer receptical, dash cluster and removed the radio to acces the GEM module / relays and unplug them.
After talking to a FORD ASSET trainer he said to check the wiring harness that runs on top of the tilt steering. Sure enough it was penetrated by metal part of the rubber seal for the shifter!
I pulled down the steering covers and repaired the wiring. All back to normal for now.
The Ford Instructor said I may have issues down the road with the GEM module or PK relay but for now all is working!
<input id="gwProxy" type="hidden"><!--Session data--><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
Old Dec 22, 2011 | 08:55 PM
PA-Mark's Avatar
PA-Mark
<INPUT id=gwProxy type=hidden><!--Session data--><INPUT id=jsProxy onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" type=hidden jscode="leoInternalChangeDone()">
Good to hear
chrisgoat
Electrical Systems/Wiring
May 31, 2018 06:32 AM
IHateCommieCars
Apr 1, 2015 12:42 AM
Furyus1
1983 - 2012 Ranger & B-Series
13
Jan 8, 2015 12:24 PM
ron7
1997 - 2003 F150
Oct 17, 2007 11:31 AM
350FOOL
Nov 21, 2002 11:36 AM
