help finding a rear tank...
Old Dec 18, 2011 | 10:05 AM
jpeckham's Avatar
jpeckham
i have looked on lmc and cant find anything dealing with the rear tank on my 88 ranger. they just say i have the single 17 gallon tank. can someone point me in the right direction as to where i can find the rear tank.
Old Dec 18, 2011 | 10:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
they just say i have the single 17 gallon tank. can someone point me in the right direction as to where i can find the rear tank?
17 gallon mid-ship (in front of the rear axle) fuel tank: 1985/88 Ranger w/a 114" wheelbase (not a Super Cab). The following is the only other fuel tank Ford offered (as an option).
E5TZ-9002-F .. Aft Axle 13.5 Gallon Fuel Tank-Use as auxillary tank / Obsolete
Applications: 1985/88 Ranger except Super Cab. There is no aft axle (rear) tank for a Super Cab available, because Ford never offered it.
No Ford Dealer or obsolete parts vendor has any.
Old Dec 18, 2011 | 11:43 AM
crerar's Avatar
crerar
First I would like to say that I have tremendous respect for Bill's extensive knowledge of Ford parts and his generous sharing of that invaluable knowledge with the group. I, on the other hand, only know what is in front of my long nose
I happen to own two supercab rangers with the front-and back dual tank option (the 87 and the 88). These certainly appear to be factory jobs, and I can only assume this is the 13 gal tank. This doesn't seem to be a common option, but I do see them in the wrecking yard now and again. They are steel tanks, so prone to rusting at nearly 25 years, so you'd have to be vigilant for signs of leaking and be ready to do a tank internal reconditioning (whole lot easier to do before you install the 'new' tank.
I looked on Car-Part.com--Used Auto Parts Market and found rear tanks available, 2 of them listed as 'A' grade, all 3 for some reason in Canadian wrecking yards. Good luck with your quest!
Old Dec 18, 2011 | 11:48 AM
jpeckham's Avatar
jpeckham
would the bronco II tanks that they have for the front be able to bolt into the back?
and what your saying is that there are no manufactures that make the back tanks anymore?
Old Dec 18, 2011 | 12:08 PM
NumberDummy
The aft axle tank is obsolete from Ford, no one has any.
Dunno if the aft axle tank can be bought in the aftermarket sector...and Bronco II isn't the same.
Old Dec 18, 2011 | 12:10 PM
crerar's Avatar
crerar
I really doubt the Bronco tank would fit. It appears to be a larger (19 gal) tank, and the Ranger rear tank fits pretty tight behind rhe rear axle (where the spare tire mounts on single tank trucks).
It's kind of odd, searching Bill's part number brings up a Google hit on Ford Gas Tank - Huge Inventory @ iAutoBodyParts.com, with a description of a 13.5 gallon rear tank for single cab Rangers. However, following the link to their site, there is a note that they have changed suppliers and their catalog has changed. Searching their online catalog lists only front (side) tanks. Guess you could contact them, as it appears they used to sell a rear tank.
Old Dec 18, 2011 | 12:34 PM
Old93junk's Avatar
Old93junk
I walked past 2 Rangers with the rear tank option in the J-yard yesterday............Look there first.
Old Dec 18, 2011 | 12:52 PM
jpeckham's Avatar
jpeckham
its an extended cab truck if that helps any
Old Dec 18, 2011 | 06:58 PM
NumberDummy
Extended Cab = Super Cab. Ford did not offer an aft axle fuel tank for a Super Cab. I made that plain in post #2.
The ONLY aft axle fuel tank listed in the parts catalog (*) for 1985/88 Rangers is for the 114" wheelbase, which is not a Super Cab.
The short bed wheelbase is 108" .. long bed wheelbase is 114" .. parts catalog doesn't list the Super Cab's wheelbase, but I think it's 123."
* 1980/89 Ford Light Truck Parts Catalog / Text-Section 90, Page 2.
September 1985: I had one of the very first 1986 (first year it was offered) Super Cab Rangers in CA. My previous company vehicle was a 1985 Ranger w/a 7' bed.
I'm 6-5, the cab was uncomfortable because the seat was all the way back, so it couldn't be reclined.
The Super Cab's front seats could be reclined when in the furthest aft position...allowing for more 'stretch-out' room.
btw: My sig pic was taken at an FTE SoCal Chapter GTG at El Dorado Park in Long Beach, April 2011 by FTE Administrator IB Adrian.
Go to the SoCal chapter forum, look at the April GTG pics for this oversized ex-Ford partsman, I'm wearing an Hawaiian shirt (my usual attire).
Old Dec 18, 2011 | 09:35 PM
arctic y block's Avatar
arctic y block
I put a NEW rear tank in my 87 about a year ago. It was totaled a few months later and is being parted out. I got the NEW tank from a vender that had 6 at the time. They have none now. PM me if you want the tank cheap.
Old Dec 29, 2011 | 07:24 PM
DANRL's Avatar
DANRL
I'll take the tank!!! - Dan (danandannl@hotmail.com)
Old Dec 29, 2011 | 10:08 PM
arctic y block
Email sent to ya. I will check with the other guy and see if he still wants it. If not you can have it.
Old Mar 29, 2018 | 12:35 PM
clazman's Avatar
clazman
rear tank am I too late?
Old Apr 14, 2018 | 09:47 PM
clazman's Avatar
clazman
Ranger rear tank wherefore art thee
My search has been mighty grim.
My mechanic had a couple shipped in from a list of yards I gave him. The tanks were in as bad a shape as the one I already have.
I suggested restoration and was politely put down.
I thought I had one the other day. But it turned out to be a NO.
I had just bought this '87 Ranger from the neighbor across the street of all things. Had 27000 miles on it. Her nephew had
had the truck done over pretty good just before I bought it: new brakes, new shocks, new battery, new tires. and new exhaust.
After I bought it I had to have the pressure regulator replaced (it was allowing fuel pump pressure to the injectors since its diaphragm was shot) That was all that kept the engine running for the fuel filters were plugged solid and the injectors were partially plugged too. With an ignition module I have show room truck now. $2500 later.
lambchops25
17
Jul 16, 2022 09:48 PM
tbruz
Oct 23, 2015 01:46 AM
beersy50
Oct 11, 2014 10:17 AM
bronzeback
Sep 29, 2005 06:41 PM
