dyno day v1
Old Dec 18, 2011 | 08:29 PM
91dirtydiesel's Avatar
91dirtydiesel
I have turbo and stock cam, I need to email Eric for my full sweep sheet, I have a zoomed in one but doesn't show the curve very well
Old Dec 18, 2011 | 08:31 PM
starmilt's Avatar
starmilt
Originally Posted by typefour
When nmb is dialed in we are going to do a timing day down here in portland cause there a lot of members that want to come from eastern or and such.
I did nothing to mine except the new air filter, I was happy with my 80k daily driver .
And on my alst pull we checked and i ONLY HAVE 2PSI gotta fix that.
is this a misprint, should that have 12 instead of two, and is that what you think the psi was on the run we have the graph for.
Old Dec 18, 2011 | 08:44 PM
91dirtydiesel
this is the one where all the cams are in it (this was my first run, the big blue line is because i held the same rpm to long before i backed out and it kept sending data)
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=dynocams.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/dynocams.jpg" border="0" alt="Photobucket"></a>
Old Dec 18, 2011 | 09:05 PM
starmilt's Avatar
starmilt
That makes the aftermarket cams look pretty good to me. If my math is close double over should get me somewhere in the 1650 rpm range at 70 mph. If that is right the type four cam would be my best bet, even dropping out of one over on small hills would get me real close to optimum torque range.
Thanks for the graph comparisons, I definitely see a cam in my future. lol
Old Dec 18, 2011 | 11:17 PM
typefour's Avatar
typefour
no misprint. and yes it was the same on all, and no the fuel filters are not old.
Old Dec 19, 2011 | 12:32 AM
starmilt's Avatar
starmilt
What do you think the problem is, a leak maybe.
If you only had two pounds of boost, it would be impressive to see what it would do at ten.
I would have expected a cloud of smoke at 2 pounds.
Old Dec 19, 2011 | 03:42 AM
91dirtydiesel
Talkin bout fuel pressure, not boost pressure lol
Old Dec 19, 2011 | 12:54 PM
starmilt's Avatar
starmilt
DUh I was scratching my head, thinking this there was no way this could be right. lol
It is pretty impressive that he could get those boost numbers, with 2 pounds fuel pressure.
Old Dec 19, 2011 | 05:45 PM
typefour's Avatar
typefour
Probably just enough to feed the pump, I have had some very dirty, read free ,fuel in the past maybe time to blow out all the lines and stuff.
Old Dec 19, 2011 | 06:43 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
'91 why does your power band not start recording until 1600 rpm though?
Russ,so you basically have like 300ft lbs already just off idle a bit (well,i guess that's still twice idle rpms or so,but still holy crap,what a good economy cam for street use and tow duty.) around 1100ish maybe that's closer to 1200 rpm it looks like with that cam.am i reading that right?
Old Dec 19, 2011 | 07:00 PM
91dirtydiesel
My tires and gearing, when he loaded me up lower I was just completely bogged
Old Dec 19, 2011 | 07:12 PM
FORDF250HDXLT
oh yeah,dang i forgot about your effective gear ratio right now.man,you need to fix that.stop and go driving is killing your economy right now.bogging out until 1600rpm taking off isn't no good.man,you wouldn't want to try and tow anything.it'd feel like a gasser.
Old Dec 20, 2011 | 12:18 AM
  #28
91dirtydiesel
Haha I know! Just gotta find some time to work on it...just bought nmb2s old 7.3 with 137000 on it and already got a buyer lined up for 850!!! So that should pay for it....and since I made out good I said I'd also pay for nmb2s dyno run
Old Aug 29, 2012 | 02:56 PM
  #29
91dirtydiesel
round two!
another mini dyno day will be happening tonight....same place...
as far as i know it will be:
myself (91dirtydiesel)
racinndrummin
nmb2
lil red sled
racin and I did this dyno in the past so it will be interesting to see our past and present runs.
im not sure what all racin has changed since last run but this was my set up previously:
4.10 gears, 38" tires, ATS turbo, 4" intake with AEM filter, 3" DP, 5" exhaust, NA ip maxxed out
current set up:
4.10 gears, 35" tires, ATS turbo, PSD intercooler, 3" charge pipes, R&D intake manifold, 4" intake with AEM filter, 3" DP, 4" exhaust, Turbo ip maxed out
we shall see if anything changes.
also cant wait to see the numbers that the justins lay down!!
Old Aug 29, 2012 | 04:31 PM
  #30
kobaltblue's Avatar
kobaltblue
Cant wait to see them dyno numbers, I'v got another project in mind that will be gettin some upgrades.
