Air filter warning light and transmission?
Just make shure you check that filter minder first they do have a tendency to fall apart and that turns the light on
that is assuming you have the stock air filter system still intact an is actully one part they got right
Justmake shure you get the air filter with the blue filter media
try these guys for filters
Home - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
great deals Here^^^^^^^^^^
A
The tranny issue will probably be less expensive since you didnt run that tunner
have you gotten a copy of Bismics spread sheets?? He has some good tranny info in them
And it maybe something like the shift silinoids or something
Just thought it was odd that you didnt have a tunner then a few posts later you had one. But I see now what you mean about the tunner you just dont use it the programming part
Gotcha No Worries
A
Gotcha No Worries
Do it at a dealer. Usually under 200 bucks. The tranny has an internal t-stat that doesn't fully circulate the fluid till 170 degrees. That's the reason for the hot flush. Some shops say they have one but only have a standard flush machine. I also don't trust indies to use the proper fluid. Very, very important that only mercon SP or LV be used. Some will tell you that their fluid meets the specs. Don't believe them. Also on the air filter. If you change it use only the blue fiber Donaldson or Motorcraft brand filters.
