Sponsored by: Real Truck
Charging issues
Old Dec 17, 2011 | 01:55 PM
idaho86f150's Avatar
idaho86f150
Charging issues
So I have been having some issues. Here is what has been done so far:
~Two new battery's. The old ones were getting weak.
~New Alternator.
~Did a voltage test and at idle I was getting 12V. Let it sit and run for awhile and it dropped down to 11.95V
~I took the connector off the alternator and with the key off, one of the terminals has power, and when the key is turned on the other terminal gets power.
If I rev the engine up to 2000RPM I can get a voltage reading of 13.2V. So the power is traveling from the alternator to the battery. The readings off the alternator are also the same as the ones from the battery.
Any ideas/suggestions?
Old Dec 17, 2011 | 10:21 PM
99f350sd's Avatar
99f350sd
What truck and year? battery charging voltage should be above 14v with charged batteries..14.4 usually unless the batteries are really run down. Sounds to me that the alt is bad or some wireing issue.
Old Dec 17, 2011 | 10:33 PM
twags6's Avatar
twags6
I'm guessing by the fact that you replaced both that you have a diesel. What brand alternator did you put in? The remans and even some new ones are known to have DOA parts right out of the box. Could be that the voltage regulator is shot already. Another thing to check is that there are no fuses blown. My truck has one 10 amp mini fuse under the hood. Yours should have one somewhere.
EDIT: Is this the 99 F350 7.3L PSD you've posted about in other threads? I'd check to make sure that plug on the alt is snug. Even try wiggling it around while its plugged in. They get loose after a while and poor contact could be the issue too.
Old Dec 19, 2011 | 12:07 PM
idaho86f150
Sorry for the late response.
Yes it's a '99 F350. 7.3.
How long should the glow plug relay stay hot? I started it up yesterday and after running for 10 minutes or so there was still power going through relay.
I thought they were supposed to shut off after the first two minutes or so?
The alternator is a NAPA reman. I had them test it before I went out the door and everything came up good. For what that's worth.
All the battery cables got cleaned and the alternator wire terminal got cleaned.
Old Dec 19, 2011 | 12:53 PM
idaho86f150
I just went out and tested the GPR.
With the key on, and my tester hooked to the two small terminals I am getting 12V.
But with the key on I am not getting 12V to the hot side.
Old Dec 19, 2011 | 01:14 PM
idaho86f150
Okay final update.
I think the Glow plug relay was the culprit.
I believe it was stuck open, causing a major amp draw etc etc. And then it must have finally burned out because now I am getting zero volts through it.
And my alternator is now showing 14.4 volts
Old Dec 19, 2011 | 01:15 PM
twags6's Avatar
twags6
Both of the small terminals will show around 12v because the PCM grounds the one lead instead of powering it. The large terminal with the black/orange wire should be hot all the time and the one with the brown and yellow wires should be hot for 0-120 seconds depending on the outside air temp and oil temp. Are you saying that neither large terminal has voltage? If thats the case, either a wire is loose or a fuseable link blew in the black/orange wire, which also happens to be the same wire that the alternator charges the truck with.
Old Dec 19, 2011 | 01:18 PM
idaho86f150
The black orange wire does have power.
The 'cold' side of the relay that powers the Glow plugs does not.
The red small wire has 12V, which I believe to be correct. And the other small wire works as a ground.
I double checked a wiring diagram and all the wires are going to the correct spots.
At least I am getting the correct voltage now with the relay un hooked
BDodson
Apr 5, 2018 05:26 PM
Gordesky Mco
Bronco II
Mar 19, 2015 12:25 AM
jonnygorgo
29
Mar 12, 2014 06:36 PM
Wog22
1997 - 2003 F150
Mar 20, 2011 11:49 PM
mhalter
Electrical Systems/Wiring
Jun 21, 2003 02:06 PM
