Internal Cooler
Old Dec 16, 2011 | 08:49 AM
wesran's Avatar
wesran
Internal Cooler
I have a 2004 6.0 PSD w\90000 miles as I was returning home from a fishing trip about a hundred miles from home exited off Interstate and as I accelerated the engine sounded kind of rough but soon quieted down but about two miles down the road white smoke bellowed out the exhaust and enguled eveyrthing and I could smell coolant and noticed the temp gauge climbing, pulled off and the smoke seemed to disapate but I shut it down anyway. Checked all hoses no problem there no water in oil so was at a lose so had it towed to dealer. Was told it was probably an internal cooler. Have never heard of such a thing and wonder if some one can enlighten me. It will be Monday the 19th before they can look at it and I would like a little knowledge before the jump off the deep end. Thanks
Old Dec 16, 2011 | 09:15 AM
Maxium4x4's Avatar
Maxium4x4
The internal oil cooler plugs, restricting coolant flow. The EGR cooler fails from over heating sending coolant out the exhaust. Both need to be replaced when a failure occurs for example: EGR cooler only, does not address the internal oil cooler. If you choose to delete, you still must replace the internal oil cooler.
The 6.0L Bible in the Tech Folder has information showing components and flow.
Old Dec 16, 2011 | 09:37 AM
zhilton's Avatar
zhilton
The white smoke was coming from your EGR cooler that failed because it was more than likely starved of coolant. Which happened when the oil cooler clogged. Some what common problem with the 6.0L; if you catch it quick enough by monitoring the engine via aftermarket gauges you can usually get by with only an oil cooler change. As John has already pointed out, when they replace the EGR cooler...make sure they replace the oil cooler as well. Or you'll be back the shop to have another EGR cooler replaced within months.
Old Dec 16, 2011 | 10:33 AM
wesran's Avatar
wesran
Thanks for the quick responses. Another question how extensive is the oil cooler change?
Old Dec 16, 2011 | 10:53 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is a link of the job. Gives you an idea how deep you go to change it out.
http://www.newyorkmustangs.com/forum...ld-t13149.html
I have not done this repair, a lot of guys on here have. And have had success doing this.
Some in a garage and some in a driveway.
Old Dec 16, 2011 | 11:03 AM
Rusty Axlerod's Avatar
Rusty Axlerod
You did good having it towed also. Driving it like that can cause even more damage. I would suggest not to start it either. Coolant can leak into the cylinder with the intake valve open and fill it with coolant causing a hydrolock. Starting it with that condition can squirt head gaskets or even bend connecting rods.
imcqueen
Nov 16, 2017 04:50 PM
rjglenn
May 9, 2014 04:48 PM
lupuseven
Nov 26, 2012 07:38 AM
wingrider75
Oct 23, 2012 12:19 AM
scameron
Feb 2, 2009 04:15 PM
