DEF
Old Dec 16, 2011 | 01:41 AM
1L243's Avatar
1L243
DEF
Ok I have been finally getting to the point where I can start thinking about a new truck and then I came across post on the DEF required... What is DEF?
Old Dec 16, 2011 | 03:05 AM
khadma's Avatar
khadma
Carpenter Local 745
http://media.ford.com/images/10031/S...rtreatment.pdf
Take a look.
Old Dec 16, 2011 | 05:27 PM
Dim Sum's Avatar
Dim Sum
Its a urea solution that is used in the exhaust after treatment to convert the NOx into less harmful N2 and O2.
Generally we are seeing about 1-2 gallons per thousand miles of driving. The stuff can range for about 3 bucks a gallon at big truck stops to $10 bucks for 2.5 gallons at Walmart.
In today's diesel technology, urea is a good thing as it lets manufacturers run hotter cylinder temperatures which mean a leaner burn. Leaner burns mean better FE. As well, Ford is able to run less EGR (exhaust gas recirculation) and that is generally a good thing.
BII Plow Truck
General Diesel Discussion
Nov 10, 2016 03:41 PM
rob17
6.7L Power Stroke Diesel
Jan 29, 2015 01:21 PM
Shoo12
6.4L Power Stroke Diesel
16
Jan 13, 2014 12:55 PM
parkland
Feb 14, 2012 10:00 PM
Jonboy
Sep 8, 2005 06:12 AM
