05 coil spring front end install
Old Dec 15, 2011 | 10:53 PM
sidwaz's Avatar
sidwaz
Does anyone know where I can find a detailed write up on this swap for my 02? Unfortunately I just put all new ball joints, axle u-joints, ball joints, tie rod, and drag link on my front end. Are any of the steering parts useable for this swap? I currently have a 8" lift installed so I will keep the current steering box abd pitman arm. I have a 4 link of unknown make that was removed from an 05 that was smashed in the front. Everything looks good except two of the control arms are bent. There is a different bracket on the front axle for the control arms to mount to. The control arms are grey and not adjustable and have poly uerethane bushings on both ends. It also has dual shocks mounted to hoops with remote resevoirs again no hint of make here either. Any idea what make this kit could be? I would like to be able to order the two control arms or possibly make new adjustable arms.
Old Dec 16, 2011 | 01:00 AM
Bonanza35's Avatar
Bonanza35
Can't help you with this one. I've never heard of it being done. I know the new trucks turn sharper then ours so not so sure your steering box is up to it. Let us know what you end up doing and how it works.
Chet
Old Dec 16, 2011 | 06:02 AM
Dean88's Avatar
Dean88
There was an OBS with this swap done in Diesel Power a few months ago, so I know you can pull it off.
Old Dec 16, 2011 | 08:38 AM
timmyboy76's Avatar
timmyboy76
good luck with it...btw, think you can find the control arms, locally from the C.L. list, from people wo've done a 5ft lift on their rigs...
Old Dec 16, 2011 | 10:18 AM
kccatpower's Avatar
kccatpower
are you wanting to keep your 8" lift or go back to stock? skyjacker made a coil conversion lift kit you might want to check into.
Old Dec 16, 2011 | 11:22 AM
Layson's Avatar
Layson
Need some pictures of what you got. Otherwise it is just a guess.
Does it have an adjustable track rod or a drop bracket?
Bruker
1983 - 2012 Ranger & B-Series
Nov 20, 2018 08:17 PM
walexa
Feb 18, 2018 02:36 PM
pcavender
2004 - 2008 F150
55
Jan 25, 2011 01:34 AM
Snobord28
Dec 16, 2010 07:16 PM
