Dad's Truck Build
#4008
#4010
#4011
Well,I hope to be somewhere in the line...Maybe before Christmas...Trav.
#4012
I am in a Mexican standoff with the Broncos future owner right now. Only the Lord knows when that will end.
#4013
#4014
#4015
On the other hand, go with those pistons and use the D8 heads and the extra ~6 CC's in the combustion chamber works out the same on compression. And the only work is porting, and even with the E7's you should remove the humps.
Wait! I just hijacked my own thread!
#4017
Future owner?
#4018
Kris. He is refusing to get a job and work and I am not having it. He finally broke down and interviewed at Mathis Brothers furniture the other day. His Grandpa told him he would foot the bill for the front end rebuild and whatever else the Bronco needs to be reliable. I told his Grandpa he isn't spending a dime on the Bronco until he gets a job. And that's going to be that!!
#4020
Yes, I called Massey's yesterday. Looks like it'll be November before I get the seats, but that's not a problem as the truck doesn't go in until mid-December. So that'll give me plenty of time to sort out the seat mount situation.
What seat mount situation? The line of "stuff" I've been selling that I'll use the same mounts on the passenger's side as the driver's side, replacing the ejection seat mount. Well, that was ..... ill-informed.
What's the prob? Actually, there isn't a problem on the driver's side. But, as it turns out the rails for the driver's side don't work on the passenger's side w/o swapping them, which won't work. SO, DID ALL OF THE BUCKET SEATS COME WITH EJECTOR MOUNTS ON THE PASSENGER'S SIDE, OR DID SOME COME WITH SIMPLE RAILS LIKE THOSE ON THE DRIVER'S SIDE, BUT REVERSED???
Hopefully you can see the problem in the pictures, but here's a description:
- This is a shot of the inside of the cab on the driver's side with the factory holes at the bottom of the picture and the inside holes marked in yellow at the top left and right. Note that the front holes are in the sloping section of the floor pan. And, that the inside front one is right on a crease. I may need to weld a reinforcing washer, suitable bent to fit the curve, on the underside of the floor.
- This is the bottom view of the driver's side of the cab, with the inside holes again on top and the outside holes on the bottom in the reinforcing rib. No problemo, but the inside back one is pretty close to the seat belt reinforcing washer, although that's not a problem if I just glue a reinforcing washer on the inside to spread the downward force on the seat.
- This shows the ejector seat base with the driver's side rails bolted onto it, using the ejector base to space the rails apart correctly. Note that the outside rear bolt is in and the base is sitting down on the floor there.
- Here we see the problem, Houston. The distance between the holes on the outside rail is about an inch longer than it should be, so the front of the rail isn't touching the floor. And, the inside front isn't even that close.
- The inside rail sits an inch off the floor at the back
- This shot is with the inside rail moved to the outside - it works, but then the mechanism is in the wrong spot and the seat is moved inboard 3".
- And this is with the ejector base installed and the back holes are about 2" shy of the factory back holes.
