Idle problems
Old Dec 15, 2011 | 01:46 PM
Fordtruckman7988's Avatar
Fordtruckman7988
Idle problems
I have a 1992 F250 4x4 with the 5.8l. I just bought it recently to drive to work. I replaced the tps and the idle sensor that is on the side of the throttle body looks new. It idles very high rpm, when you put it in gear it jumps in gear real hard (due to rpm). Is there any suggestions out there other than vacuum leaks? Thanks
Old Dec 16, 2011 | 08:14 AM
rla2005's Avatar
rla2005
Does it still idle high with the IAC (the solenoid on the side of the throttle body) unplugged? If it does you are still looking at a vacuum problem or someone before you has jacked with the Idle stop screw.
Old Dec 16, 2011 | 12:07 PM
fonefiddy's Avatar
fonefiddy
Check the vacuum reservoir. They are notorious for corrosion, leading to a major vacuum leak. Remove nuts from the underside of the pass fender liner.
Old Dec 16, 2011 | 01:22 PM
rla2005's Avatar
rla2005
Good point fonefiddy. I am sure the OP has a vacuum assisted cruise control like mine. There is another metal reservoir behind the driver side headlight.....
HuntingRat
24
Dec 1, 2017 12:22 PM
chertel4
Feb 27, 2017 09:48 PM
gsibert
Jul 2, 2010 11:33 AM
unclethumbtack
May 10, 2010 09:08 AM
chirps2nd93
Jan 9, 2007 07:48 PM
