Sponsored by: Auxito
need help with ABS problems
Old Dec 14, 2011 | 07:28 PM
Indot29's Avatar
Indot29
i have a 2003 F150 FX4, 5.4 V-8. When i first start the truck and take off the ABS system acts like it wants to work and then the ABS lights comes and stays lit.I dont think the system is working when the light is on. What should I check and where to start. Any ideas.... (Took it to a local parts store and they put it on the scanner and would not communicate with the ABS system.. Please help. Thanks
Old Dec 14, 2011 | 08:38 PM
Thomas Hutchins's Avatar
Thomas Hutchins
Take it to a FORD Dealer or to a Brake specialist and have them scan the ABS unit, takes a special tool. That is the only way I found a faluty ABS Sensor on the right ft wheel.
Old Dec 14, 2011 | 08:39 PM
Dave G.'s Avatar
Dave G.
I'd check the fuses first for the ABS. If those are OK, each wheel has a sensor, and those can get damaged or disconnected when work is done on the truck. The sensors are in close proximity to a steel part that resembles a gear. If any of those are damaged, full of mud/rust, or bent/broken, the signal is faulted and the light comes on. You need to be moving at least 5 mph for any of that to function.
Also check all the harness connections for damage.
Dave
Old Dec 14, 2011 | 08:51 PM
Indot29's Avatar
Indot29
Thanks, thats a place to start looking.
Blue7.3
Australia Chapter
Feb 11, 2015 01:45 AM
beartracks
Jun 19, 2011 11:42 AM
Big Greenie
Oct 6, 2010 01:27 PM
ITFD
May 26, 2008 08:19 AM
tpgeneral
1997 - 2003 F150
Nov 27, 2006 07:30 AM
