Slave cylinder issue
Old Dec 14, 2011 | 03:59 PM
Mtnplow's Avatar
Mtnplow
Since I upgraded my 84 f350 to a 92 cab I have run into a clutch problem. I switched over to a 92 slave cylinder due to the mounting studs and after bleeding I still can not engage the trans into gear. I did replace the clutch and pressure plate and with the motor off I was able to go through the gears but now I have it started nothing can't get it into gear. I was wondering if the newer slave cylinder is compatible with my T19 setup.
Old Dec 14, 2011 | 08:39 PM
kedwinh's Avatar
kedwinh
It really shouldn't have anything to do with what trans your running, it's all about the clutch and throwout arm/bearing. I'm assuming the clutch pedal works as normal. Maybe have someone press the clutch while you check to see if it moving the throwout are.
Old Dec 15, 2011 | 06:40 AM
Mtnplow's Avatar
Mtnplow
It's moving is there a certain distance I'm looking for, being there is no adjustment he has me thinking it's the slave cylinder.
Old Dec 16, 2011 | 10:18 AM
stuart1's Avatar
stuart1
Is the fire wall cracked? The wall will flex and take the cylinder out of the equation.
Old Dec 16, 2011 | 11:39 AM
kedwinh's Avatar
kedwinh
Never really measured but would think 3-6". Should be far enough to activate the throwout bearing and pressure plate. Like stuart1 said, these trucks are known to have a problem with cracking firewalls, so that could be a problem to. But speaking from my own personal experience, I had to replace both my master and slave on my 85 not to long ago for almost the same reason after I had replaced the clutch. It worked fine with the old worn out clutch but not with the new one.
Old Dec 27, 2011 | 11:24 AM
artfd's Avatar
artfd
Exclamation
There have been a great many comments on difficulty properly bleeding the clutch hydraulics after they have been replaced in a manner similar to what you have done. Search all the forums.
mic91F150
Nov 29, 2016 11:14 PM
Cayton
Jul 12, 2016 07:27 AM
FordOwnerJoey
Feb 26, 2014 02:30 PM
deetown
Jul 10, 2008 09:47 PM
ziller
May 29, 2002 09:43 PM
