Gear ratios
Old Apr 15, 2003 | 10:33 PM
jbooker82's Avatar
jbooker82
Gear ratios
Does anybody here run 4.56?
What RPM does it run at ?
What is your tire size?
What transmission do u have, auto or 5 speed manual?
Old Apr 16, 2003 | 11:50 AM
GAV10's Avatar
GAV10
Gear ratios
More Info ? Truck type ? F-150-F-250 etc. Engine size ? 4.6-5.4-6.8 Transmission type ? Auto 5-spd 6-spd Stock Tires ?
You will probably get a better response posting this question in the forum that applies to your truck.
Mark
Old Apr 16, 2003 | 08:34 PM
jbooker82's Avatar
jbooker82
Gear ratios
89 F150
Mazda 5 Speed
5.0 HO
Looking at running 37 in tall tires.
Old Apr 16, 2003 | 10:05 PM
Rand's Avatar
Rand
Gear ratios
I wouldnt go above 35" because those axles are pretty weak to be turnin 37" tires.
35" tires and 4.56 gears would probably be ideal
Rand
Old Apr 16, 2003 | 11:02 PM
elliott's Avatar
elliott
Gear ratios
Go to www.ring-pinion.com and fill in the blanks. It is the best/quickest table I've found.
