General Carburetor Jet Question
Old Dec 14, 2011 | 07:14 AM
Rick_Fury's Avatar
Rick_Fury
In tuning my carburetor, I have found that for maximum RPM and vacuum, my mixture screws are only turned out about 1 full turn from all the way in to lean. Does that mean anything? Should I go with a smaller size jet? Would difference would I see economy wise or performance wise if I went with a smaller jet, and say, 2-1/2 full turns our from lean?
Also, for a 4-barrel carburetor, what would be the typical difference in jet sizes between the primary and secondaries? For example, if I am running a size 50 jet in the primaries, how much bigger would the secondary jet be from the primary jet?
Old Dec 15, 2011 | 03:49 PM
Beechkid's Avatar
Beechkid
Ideally you should be at 1.5 turns out...but that's close enough. With regards to jet sizes, we I would need alot more info such as max engine CFM, current carb cfm size & primary jet size
Old Dec 15, 2011 | 03:57 PM
Rick_Fury's Avatar
Rick_Fury
Thanks, Beechkid.
I thought I read somewhere once that if your idle is not best at 2 - 2-1/2 turns lean out at least, you should go down (or is it up?) in a jet size.
Or something like that.
Old Dec 18, 2011 | 01:39 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
The idle circuit is completely separate from the main circuit. Changing jets will have no affect on how the idle mix screws are set.
ON the secondaries, the only way to know for sure is with a wideband O2 sensor or a few trips down the drag strip. You can seat-of-the-pants guestimate by making a WOT run, changing to larger jets, make another WOT run and if it's faster repeat until it's not then go back one size.
Ira Brown
May 21, 2015 03:53 AM
Rick_Fury
Dec 14, 2011 07:52 PM
4x4 Bart
Oct 28, 2010 06:30 PM
my64gal
Jun 10, 2010 03:42 PM
BinderBoy
Apr 6, 2000 10:09 PM
