I would sell the drums I just need to know if the disk brake conversion will work with my axle or will I have to get a f100 axle once I get that answer ill let you know when I can sell them and then I can sell all the old wheels I have too because ill have a common 5x5.5 bolt pattern
Let me know when you get to the point where you're not needing the drums and wheels. I'm just about done with the chassis, but haven't started on the cab yet, so whenever it works for you. The best way to keep in touch may be email. gsbrandon@usa.net
thanks same for you good luck with you project. and you need the rear dually drums right? the disks for me are for the front of my truck, i am swapping the rear to a ford nine each for rear drums for me is not a problem
