IVS part number
Old Dec 13, 2011 | 12:40 PM
nomad221's Avatar
nomad221
IVS part number
Has anyone recently replaced their IVS ? Mine is acting up. Periodically I'll press down the accelerator and can not hear the micro switch "click".
Thanks fellas.
Old Dec 13, 2011 | 12:49 PM
fordpride's Avatar
fordpride
You can't but it you would have to buy the whole pedal assembly $$$$ or find a used one.
Spray contact cleaner in it and blow it out with air
Old Dec 13, 2011 | 05:18 PM
strokin'_tatsch's Avatar
strokin'_tatsch
look at the IVS while you press the pedal down. There is a tab on the pedal that moves away from the IVS when you push the pedal down. If the tab is bent too far away from the magnet on the IVS, the magnet won't pull to the tab when you release the pedal. If that's what's happening, bend the tab towards the IVS a tiny bit until it clicks back everytime you release the pedal and releases as soon as you press the pedal down a little.
n20
Mar 29, 2010 02:34 PM
Kelsokell
30
Mar 17, 2006 11:24 AM
CruisnPhantom
Feb 14, 2004 09:04 AM
Dwights
Mar 23, 2002 07:48 PM
