1978 - 1996 Big Bronco
Bw 1356 question
Old Dec 13, 2011 | 10:25 AM
jahollis2380's Avatar
jahollis2380
Bw 1356 question
I have a bw1356 t-case on a 90 f150 i can use to replace the one in my 89 bronco, my question is the one on f150 has a different output shaft going to the rear axle. The f150 has a long one and the bronco's is short with a two u-joint setup. Can i swap the output shafts out?
Old Dec 13, 2011 | 10:53 AM
Kemicalburns's Avatar
Kemicalburns
Greystreak i believe knows for certain but i recall him saying the output shafts may be different diameters. you would have to take the cases apart and swap which would be pointless in my opinion. I would try and trade for a bronco case or sell what you have and get the correct one.
Old Dec 13, 2011 | 10:56 AM
jahollis2380
Thats about right.
Old Dec 13, 2011 | 04:29 PM
masseysbronco's Avatar
masseysbronco
Yes you can, but instead of tearing 2 cases apart, why not just tear the bronco one apart and rebuild it for about 100 bucks?
Old Dec 13, 2011 | 06:25 PM
jahollis2380
I just dont think i can handle that job!!!! Not rebiulding one!
Old Dec 13, 2011 | 07:37 PM
masseysbronco
Swapping the output shafts would involve a rebuild. I assume you were thinking that you would only have to swap the tailshaft on the cases? The actual output shaft from the pickups is several inches longer than the ones in the bronco. You can swap them around but you have to disassemble both cases to do that. There isn't very much going on inside the case; couple of sprokets, chain, pump, forks.....thats most of it.
Old Dec 13, 2011 | 08:23 PM
njneer1's Avatar
njneer1
Tcases are easy.......you can do it.........if you can't ......ship it to me with the parts and I will rebuild it for you for free......shipping on you of course......
Old Dec 13, 2011 | 09:24 PM
jahollis2380
I definatly appreciate that. I Believe i found one at a junk yark for 150. Is there any thing i should look for?
Old Dec 14, 2011 | 08:01 AM
masseysbronco
For your application make sure it has: fixed yoke rear output (not flange, not slip yoke (truck)), speedometer provision on tailshaft, check fluid color if possible, push/pull all inputs and outputs to see if there is any crazy play in anything, shift through the modes and see if it's working as is. Even if it is working you still need to rebuild it to ensure the pump arm mod gets done or it will suffer the same fate as your old one (more than likely).
Old Dec 14, 2011 | 10:20 AM
jahollis2380
Ok, thank you guys!!!!
Diesel_Brad
Feb 24, 2012 10:03 PM
Dodge-My-Cummins
Sep 15, 2010 06:46 AM
rustee90-150
Mar 11, 2010 08:59 PM
devin84
Nov 8, 2009 02:09 AM
jrv6a
Sep 23, 2007 01:04 AM
