Stiff Steering question
So today I jacked up the front end off the ground, fired it up, left it warming up abit first, then started turning the wheel left-right right-left, absolutely no problems with the wheels off the ground. Turns flawlessly!
I did that at least 10 times, and only once (returning to center from right) did I get a weird moaning/grind noise from the front.
So if it was a bad gear box, wouldn't it act up all the time, or only under load?
Driving it down the road, the wheel NEVER returns to center, it stays where ever you put it, and when returning it to center, from either left or right, for it to drive in a straight line without having a nasty pull, I'd have to give it a shot at the opposite direction to get it centered.
Driving straight, and turning left, it's fine, not hard to turn, but still return to center.
Driving straight, and turning right, super stiff, and doesn't return to center. Bringing it back to center, makes weird moaning/grinding noises.
Keep in mind, both lower grease caps and nipples are missing on both Kingpins. No idea how long it's been like this, but it's got pretty fresh blue grease in them.....so can't be to long.
Have you pried on the tire with them jacked tp, to see if there is any slack in the kingpins.
Can't remember if you've mentioned it, but what does the fluid look like? If its pristine looking, maybe the box isn't bad.
I'm still leaning towards a bad steering box, because if something was binding in the kingpins, I'd think it would feel the same in either direction as its basically just a cone rotating in another cone (kingpin rotating in bushing). Whereas the steering box is a somewhat complicated setup with a piston that goes one way for right, and the other way for left, and then a bunch of other stuff moving as well.
Granted you need to replace the grease caps, and I don't even know what that looks like on a van, but I'm pretty darn sure that replacing the steering box is a hell of a lot easier than the kingpins themselves. And probably cheaper if you're paying for the labor.
I think self centering has something to do with the caster setting of the axle and nothing to do with the kingpins, or the steering box itself. If there is sufficient friction in either, it probably won't return by itself.
By the way. I'm pretty sure any manual steering vehicle will turn with easy if its jacked off the ground. But the friction of the tire on the ground makes it tough to turn unless the vehicle is moving so part of that friction is overcome. If I'm not mistaken, power steering is mostly for reducing effort when steering at low speeds. Once you're rolling, it doesn't matter that much. What I'm trying to say is I don't think jacking it up really told you anything at all. It sounds to me more like a bad box.
Star, the whole front end is tight on that van, no play at all anywhere! I double checked everything again today.
Tecgod, I know caster would bother the return of the wheel.
Now this van did weigh around 9000lbs loaded, and the alignment was done loaded.
Now empty, the *** end is way up in the air, and the front wheels are like this \--/
I found some rubber coil spring spacers on both sides taking up a whole wind in the coils, looks like it's to keep the front end up for back when it was loaded to keep the camber in check.
Would having the wheels like this \--/ make steering funny?
uhmm i was out greasing the front steering and suspension about an hour ago and the driver side lower kingpin grease cap popped off as i was attempting to put some grease in
what happened ?
how do i fix it ?
do they press fit in ? or ?
why would it just pop off so easily ?
i dont think i even got a full pump of grease into it before it popped off
Reply:
I had this happen, I just cleaned the threads and screwed it back in and tighten the plug to 35-50 ft-lbs.
If it will not tighten replace the plug, base part number 3B435.
King pins will cause memory steer.
A bad steering box can also cause it.
I don't see how, really see how kingpins can make the grinding sounds you have described, but sounds are hard to describe, is the noise similar to when you have the wheels turned to the lock position and still have pressure on the steering wheel.
But the moaning grinding noise is only coming back to center from right, tomorrow if I have time, I'll find a place to mount my camera underneath the van, and go for a ride, see if we an hear something on it. I clearly hear it inside the cab!
Anyone know if I can get just those caps alone? And how do they hold in there?
Drivers side:
Drivers side top, did take grease no problem, was hard pushing the gun at first, but after a few pumps, went in no problem.
Passenger side lower:
Passenger side shot
