Sponsored by: Real Truck
no wipers, washers
Old Dec 12, 2011 | 04:39 PM
artieb's Avatar
artieb
no wipers, washers
Hi, I got a 2001 F350 PSD and I don't have any B+ at my 5 pin motor connector. I have searched, and searched on this and other forums with no luck. My dash #33 30a fuse is good? Where and when should I get B+ at my wiper motor's connector? key on? I have no relays do anything at any point of my stalk's operation and/or "jiggling" Appreciate some advice, Artie
Old Dec 12, 2011 | 07:24 PM
artieb's Avatar
artieb
I'd like to add some more info. on my underhood power dist. on relays 34 park / run and 35 high / low I do not have any B+ anywhere. Relay 33 washer pump I have B+ on term #3 no where else.... what years do I have in common with my 2001 F350? What is a good manual to get?? Which ones to stay away from? Thanks for some input, Artie
Old Dec 13, 2011 | 02:25 AM
carltonwebb's Avatar
carltonwebb
Power to that circuit starts at maxi fuse 21 under hood. It is 50 amps. That fuse feeds half the free world. Ignition switch, vacuum pump shift interlock if auto, & radio are just some of the things on it. If those work, then it is good.
Fuse 21 also feeds the ignition switch. There are 2 yellow wires there that should get power all the time.
The fuse 21 circuit leaves the ignition switch on term A1 (blk with lt green stripe) to fuse box inside to power the wiper circuit and fuel tank selector if u have and radio circuit.
Fuse 11 cab inside provides power to wipers. It provides B+ to wiper run relay term 1 & 5 , term 1 of pump relay, Term 1 of high low relay & to pin 4 (bk/lg wire) of wiper motor connector.
Relay 33 term # 3 that u have power on gets that power from Fuse 2 under the hood.
Old Dec 13, 2011 | 07:20 AM
artieb's Avatar
artieb
Carltonwebb, I can't thank you enough! No wonder there's so many wiper horror stories. Ford is running a 30a wiper circut through an ignition switch, fuse panel, bulkhead connector and a "Y" splice somewhere, TOO MUCH! IMHO.
I'm going to either find a switched B+ in my underhood power panel or run a relay control wire from the cab and wire in a 40a Bosch relay with a 30a cir brkr for the positive side of the motor, wiper run relay, pump relay, and high / low relay. Keep the wiper circut all under the hood, AND reduce the load on the ignition switch.
I don't think I want to disturb the factory's seal on the firewall connector, as we have moisure problems getting our GEM wet, since this connector is lower than the wires and water runs downhill, thru the bulkhead and into our interor electronics.
So, part of the GEMs functions is to take the control fron the wiper stalk and throw out B- battery on the relays?
IF I have no other electical issues, so I should be ok. Does this relay idea make sense???
Old Dec 14, 2011 | 01:13 AM
carltonwebb
Was fuse 11 in the cab getting power? I left out the couple of connectors and splices but can help u narrow down the original circuit if u want.
The relay idea works but it is up to you and your knowledge of circuits in general. It could be just that u have a bad connection somewhere.
The gem does supply the ground side of the circuit via stalk. A better way of saying it is that the stalk (multi function switch=MFS) sends power to the GEM. The GEM then grounds the relays based on that info. I tried to include how to test MFS but computer and I are having a disagreement
If u need more, holler back. I am a late night person so its usually early am when i am online.
Old Dec 14, 2011 | 04:31 AM
artieb's Avatar
artieb
Thanks Carltonwebb, I rang the circut from the motor connector to the bulkhead connector. When I was surprised to see 30a circut on such a small bulkhead pin, I decided to cut it loose there and go the with the relay , and control the relay with switched power. The wipers work! What else does the Generic Electronic Module control?
Old Dec 15, 2011 | 01:18 AM
carltonwebb
LOL...its almost what does it not have a hand in. Did i understand u to say that your gem took on water? For future reference if u have to replace it, u have to have that programmed to your truck configuration.
The GEM controls a variety of systems:
4-wheel drive functions
front and rear wiper/washer
warning chimes
keyless entry
interior and exterior lamps
power windows
brake warning
door ajar
seat belt switch
headlamp hi/lo
interior lamp
horn ground for relay
park brake applied light
The ignition switch position is very important to the GEM function. Often times, erratic or unexpected GEM function can be traced to problems with these GEM inputs.
Old Dec 15, 2011 | 08:34 AM
artieb's Avatar
artieb
no water on my gem, that I know about. my relay works good thanks Carltonwebb!!!
Old Dec 20, 2011 | 03:27 AM
carltonwebb
Anytime Glad to do it.
syntax_error
Sep 28, 2012 04:33 PM
Blueman2
Nov 26, 2011 12:17 PM
Fire Joe
Oct 15, 2010 06:07 PM
dubbz
1983 - 2012 Ranger & B-Series
Dec 23, 2007 08:38 AM
