Help With My Expedition
Old Dec 12, 2011 | 03:35 PM
Az58Cameo's Avatar
Az58Cameo
Hey Guys really Could Use Your Help On This
I Have a 2003 Expedition That Stalls on Me.
I Had Local Shop Change Out The Fuel Pump and It Corrected The Hard Starting That It Had But It Still Stalls (Doesn't Do It All the Time) But Will Go a Couple
Of Weeks and Then Pick a Day To Stall On Me (It Idles Down and I Have No Throttle Response) I Took It Back To The Shop and They Looked It Over and
Changed Out The Fuel Pump Relay on Fuse Panel But Still No Luck
So I Thought Maybe I Need To Take It To The Ford Dealer and I Did
They Had It 2-1/2 Weeks and I Went Back To Get It and Mechanic Said Every Thing Point's To The Fuel Pump and Said The Fuel Pump Is Bad ( By The Way when it stalls
it Won't Throw a Code) So I Called the Shop that Put New Pump In and They said To bring it back and They Put a New Fuel Pump In.and Ford Mechanic said also said they relay for the fuel pump was soldered in and could not be taken out?Told That to Small Shop Mechanic and he said they Change them out all The Time?
anyway after spending lots of money! it still stalls on me!
I Changed out the throttle position sensor but no Luck!has anyone had this Happen
to them? I Would be Glad to Here anything as to this Problem!
Thanks For any Response Allen
wikdwest
Mar 31, 2021 01:09 AM
vance
Jul 27, 2009 08:53 AM
chris 2
Sep 11, 2006 08:03 PM
Yoncalla
Oct 22, 2003 09:06 AM
broncogrrrl
1978 - 1996 Big Bronco
Mar 13, 2003 03:42 PM
