Coolant leak
Old Dec 12, 2011 | 10:34 AM
tshrager's Avatar
tshrager
Coolant leak
Started the truck this morning, looked down and had a small coolant drip. Looks like its another cold weather water pump replace. If it turns out to be the water pump, this damn thing isn't even a year old
Old Dec 12, 2011 | 12:30 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Could be the oil cooler? its common that the o-rings there go bad in cold wheather, just a guess.
Old Dec 12, 2011 | 02:54 PM
tshrager's Avatar
tshrager
That was actually my first guess Jose, but nothing in the degas bottle. Does that go bad at the oil cooler itself or somewhere else in the system? I'll go over it more either tonight or tomorrow
Old Dec 12, 2011 | 03:50 PM
baker1983's Avatar
baker1983
It could b thermostat housing
Old Dec 12, 2011 | 04:06 PM
tshrager's Avatar
tshrager
Its not. Just did 203 tstat and new housing. No leaks
Old Dec 12, 2011 | 06:45 PM
strokin'_tatsch's Avatar
strokin'_tatsch
The oil cooler would leak oil if the o-rings let go in it...
Where did you get your water pump?
Old Dec 12, 2011 | 06:51 PM
tshrager's Avatar
tshrager
Napa, thats what I'm worried about. It looks like there is a small amount of weeping coming from the sensor to the left of the t stat housing. I had a rough day today so I only glanced at it and started drinking, trying to set my mind elsewhere
Old Dec 14, 2011 | 03:02 PM
tshrager's Avatar
tshrager
Finally got around to looking for my leak. Turns out the upper radiator hose is bad where it meets the tstat housing and has a slight drip. At least it's cheap and easy
Old Dec 14, 2011 | 06:56 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Glad to hear that you found out the problem.
Old Dec 14, 2011 | 08:47 PM
BadDogPSD's Avatar
BadDogPSD
Glad to hear it wasn't the pump again!
Old Dec 14, 2011 | 09:34 PM
tshrager's Avatar
tshrager
You and me both!
Old Dec 14, 2011 | 11:46 PM
bad12jr's Avatar
bad12jr
Atleast the water pump is easier then the front cover. Believe me I know.
Old Dec 15, 2011 | 09:34 AM
tshrager's Avatar
tshrager
Yeah that front cover looks like a royal PITA.
Mr_CarMan007
Jul 8, 2016 07:56 AM
tshrager
16
May 21, 2012 05:49 PM
jtexfisher
May 5, 2011 02:03 PM
michaelbrainardatwor
Mar 16, 2010 01:40 PM
hotrod 250
Jun 29, 2009 05:20 PM
