Neighbor's friend's friend throwing parts at no start truck
I have been watching my neighbor's friend's friend
Throw parts at his truck. 1994 F150 4.9 auto.
So far
New fuel pump
Fuel pump relay
Wires
Plugs
Cap
Battery
I went to check on them and the fuel pump is NOT getting
Power.
I do not know if it was throwing a code.
I asked, but I do not know if they even checked.
So any ideas about no power to fuel pump?
Dead PCM?
So far
New fuel pump
Fuel pump relay
Wires
Plugs
Cap
Battery
Power.
Dead PCM?
I gotta say I really doubt its the inertia switch, no need "jump" passed it a quick continuity test on it would quickly tell the tail. Wouldn't hurt to check a minute no. However with no spark added to the mix the problem is very likely back before that point power wise.
You said it has no spark, does the coil have battery voltage to it with the key in "run" position, at the "Red-lt green" wire? (positive side of coil)
When the key is in the "run" position does the Red wire to say the injectors have battery voltage in it? If it doesn't its a sure bet the fuel pump relay doesn't have it either.
If the coil doesn't have bat voltage at that red-lt green wire? then its a fairly safe bet the PCM relay doesn't have power to it either. Without power to it it can't close and in turn energize the Red wire to the (but not limited to) fuel pump and injectors.
See where I'm going with all that?
Then you state "I went to check on them and the fuel pump is NOT getting
Power" but that is rather vague, could mean different things to different people.
If the PCM is getting power to close and energizing the red wire like it should, all that seams to be good to go? And has battery juice at the yellow wire to both fuel and PCM relays?
Try triggering pump to run via the self test port, ground out the port marked "fuel pump" in the diagram below with the key in the "run" position. The pump should run continuously if the pump is good and all the above mentioned circuits are functioning as they should.
Fuel Injection Technical Library » How To Run a Self-Test
Remember this is not my truck and I
Am not the primary care giver.
I did not say there is NO spark.
There is a new pump and the old
Pump was bench tested and it worked.
I plan to check self test port to ground
Pump, but I need to gain access to the
Truck. (jump 2 to 6) on the port correct?
I plan to also check ground curcuit too.
And yes I realize its not your truck....
