NOTHING CAN BE EASY!
Old Dec 11, 2011 | 08:57 PM
DIYMechanic's Avatar
DIYMechanic
Not sure. I think the kit is sized to fit the bolt and includes the tap the correct size for the helicoil. So if the bolt is 7/16, I think you would need to get the kit for 7/16, but you should probably ask them at NAPA and confirm.
Old Dec 11, 2011 | 11:07 PM
mojoman's Avatar
mojoman
Originally Posted by Ford4Life7.3
Mojo, what size did you drill them to?
I believe I used a 25/64 bit
Old Dec 12, 2011 | 12:50 AM
BuckHammer's Avatar
BuckHammer
Welcome to my world. Nothing can be easy or will ever go smoothly.
Old Dec 12, 2011 | 11:36 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Just an update: It turns out i didnt have to use a helicoil kit. The threads in the mounting plate extend deeper than the factory bolts, so ivwent and refunded my 2 bolt starter, got the 3 bolt one, and a longer bolt. Threaded it through the good threads, got it lined up through the ones i messed up and into the good threads deeper in the hole. She cranks great!
Only problem came when i cranked it over the first time. I had the hood up, turned the key and it stuttered a little, followed by a huge ploom of smoke. I thought for sure i fried something electrical. But i tried again and it went perfect. So i guess all is well.
Old Dec 13, 2011 | 06:08 AM
DIYMechanic
Sounds to me like you might need to replace your starter solenoid on the passenger side fender as well. Either that or you have a loose connection someplace. Huge plumes of smoke don't usually happen by coincidence.
Old Dec 13, 2011 | 12:35 PM
BuckHammer's Avatar
BuckHammer
I agree. I would say that a "huge plume of smoke" would generally be indicative of a problem.
Old Dec 13, 2011 | 01:45 PM
madpogue's Avatar
madpogue
Is the bolt-hole flange on the SD starter thicker than on the OBS starter?
Was the plume of smoke under the hood? If so, yeah, check/replace the relay. Or maybe you meant a plume of smoke out the tailpipe?
Old Dec 13, 2011 | 04:04 PM
91 Dually's Avatar
91 Dually
I have a right angle attachment for a drill..... 5/16 hex shaft sticks out of it to put into drill chuck.... keyless chuck at the end. It has saved my but a couple times drilling in tight places..
Old Dec 13, 2011 | 04:20 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I got a right angle attachment also.. It's soooo nice to have when your in a tight spot!!! I don't use it often, but when I do need it, it's awesome.
shore
Modular V10 (6.8l)
Sep 27, 2013 08:03 PM
wulfman
Jun 25, 2013 05:15 AM
radmacks
Sep 11, 2011 05:40 PM
61 uni
Sep 23, 2009 08:32 PM
visaggio
Aug 23, 2003 09:31 PM
