compression check on 6.9
Old Dec 14, 2011 | 10:50 PM
eatont9999's Avatar
eatont9999
Originally Posted by Scratcher
GP holes. Doing it through the injector holes means having to bleed the fuel system to get started again.
You mean pulling good injectors and replacing the crush washers twice, hoping none get stuck? I'll pass. Get an old, bad GP and use the threaded part to made a compression tester fitting. That is if you can't find a good tester with the right fitting. I've been meaning to do this for a while but I don't have a bad GP and no real reason to test the compression on my engine. Nor do I have a Diesel tester. It's in the works, though.
JHoffman93
22
Jul 25, 2014 10:50 PM
MauleOne
Dec 13, 2012 01:46 PM
archangel
Dec 2, 2007 05:55 AM
TigerDan
Mar 22, 2005 12:35 PM
mikerc
Mar 23, 2004 09:29 AM
