All about cams....
Old Dec 11, 2011 | 01:30 AM
F-250 restorer's Avatar
F-250 restorer
All about cams....
Any one wanting to buy a new cam, or to read up on them before making a decision, there is a great cam co. in Canada with a really information rich site that can help. They also have some great cams, alternatives to the big co's here.
Accelerated Motion.com
Old Dec 11, 2011 | 09:59 AM
AbandonedBronco's Avatar
AbandonedBronco
Accelerated Motion Cam and Lifter Kits
Is this the one you're meaning?
Looks interesting. I'm curious what their prices are.
Old Dec 11, 2011 | 01:37 PM
F-250 restorer
Yes, that is the co. I found their info very helpful. They offer quite a few grinds for the 300. Price would be something to think about, since postage is now international. But I enjoy finding a co. like that and knowing there are alternatives to the biggies in the U.S.
Old Dec 11, 2011 | 04:30 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Here's another alternative to the biggies; they've got a good selection of grinds for our 300s.
Schneider Racing Cams - Ford "Truck Six"
Their "little" solid lifter cam looks like it would wake up an engine. Heck, since I'll be dropping coin for screw-in studs anyway that may be the way I go.
130F Ford 240-300 Solid Lifter Camshaft
Old Dec 11, 2011 | 07:23 PM
Brian's 48's Avatar
Brian's 48
Thanks, nice site.
Now you have me thinking about adding a cam to my 300!
How can you go wrong with a good old Canadian co., probably cheeper shipping for me.
Brian
Old Dec 11, 2011 | 10:07 PM
F-250 restorer
BVA--that's a heck of a cam! Yeps, that ought to wake up any engine. It has more duration and lift than the the comp 268!! It definately won't be a hauler. Top end all the way.
But have you heard a solid lifter cam running in an engine? It sounds like the valves are tapping the lifters. But...if that's what you like....
I sort of had my eye on the A.M. cam #32631-21378. Basically, it seems like the Comp 260, almost the same #s, but with a lope due to the 109 LSA, as opposed to the 110 with the comp.
Old Dec 12, 2011 | 07:53 PM
BaronVonAutomatc
With the lash solids usually run ~6-10 degrees less effective duration than listed so it wouldn't be too bad. And the faster ramp means more torque. It sure looks healthy, but its listed operating range (1,500-5,000rpm) is the same as their hydraulic grind with 204 degrees duration. Crazy.
I do dig the solid lifter sound even though having to adjust the lash every few months is a pita.
BaronVonAutomatc
Yay! Double post!
Old Dec 12, 2011 | 09:40 PM
F-250 restorer
I think I'm going to order that cam I mentioned in a previous post. It's everything I want, with the lope too. It's a Comp 260 with a lope at idle!!! It sure sounds good to me...hauling, towing, good low end, good mid-range for the freeway, and it sounds goods driving through the donut shop too. That's important!!
Old Dec 12, 2011 | 11:16 PM
Harte3's Avatar
Harte3
Donut shop? Isn't that where the cops hang out?
Old Dec 13, 2011 | 08:35 PM
BaronVonAutomatc
I hate to be negative Nellie but one degree less lobe separation isn't going to change the idle or the powerband enough to be noticeable. Check the cam cards and there won't be much difference in overlap between the two. Call them and ask how it idles.
What cam do you have now?
Old Dec 13, 2011 | 08:41 PM
F-250 restorer
Description states it lopes at idle.
I currently have the Isky 256 cam.
Old Dec 15, 2011 | 04:16 PM
f100jim's Avatar
f100jim
Some time ago, I made an Excel spreadsheet with all of the commercially available camshafts for the 300. I have added the cams from Accelerated Motion. Here are all of the currently available camshafts for the 300. This is all based on manufacturer's data, not mine. I have sorted by Intake duration at 0.050" first, then by Exhaust duration at 0.050". The cams should be listed, more or less, in order from mildest to wildest.
Old Dec 16, 2011 | 06:51 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Guys, I'm at a dilemma.....
I want some more power, and to retain mpg, etc....I know, I know...Gotta have one or the other...
But the list I've started putting together was-
-Port the head
-Larger valves
-Steel Timing Gears
-Bore the cylinders .030"
As for a cam....my NORMAL driving/Usage band is Idle-3,500rpm....MAYBE 3,800.....Maybe...
It looks as if the Isky 256 is the ticket for me, but I'd like some more input...
This is a daily driver, and at times...Work truck....Low/Mid range power is the definant need here....Not 7k rpms of scream.....
Any ideas?
Old Dec 16, 2011 | 09:55 AM
Harte3's Avatar
Harte3
"It looks as if the Isky 256 is the ticket for me..." Correct as it is computer friendly.
