Got new tires on the Excursion...
I was really lucky, they just got these tires in on a truck from the warehouse the other day. All four have the same DOT number and the date code is 4511, so the 45th week of 2011 is roughly early November. I'm a happy camper
Shortly after arrival in staging position. Hubcaps and OEM Ford bullet nose valve stem caps removed by me upon arrival. Arrived approximately 14:00 with vehicle, but it had been in the queue since approximately 13:00. I made sure it was nice and clean for them and I specifically made a point of not shining the old tires...
It was finally pulled into the bay at around 16:30. Despite their worries about it fitting on this particular lift due to the length and weight, they made this one work. As you can tell, it was a busy day for them. There were six vehicles ahead of me at 15:00. I put 44,250 miles on the old set of Bridgestone Dueler REVO LT265/75/R16E, but I suspect they had a total between 48-50,000 miles on them with the previous owner's use too and were almost completely used up. They were incredibly noisy for the second half of their lives too.
Removing the rims to dismount old tires and install new. Note the alignment tech on the right. He had just finished staring at the "Wishing for a 7.3 Powerstroke Diesel" badge on the door for over a minute and having a very impressed/jealous look on his face...
It was a little uneasy for me to watch this, because it was rocking back and forth some while up in the air.
Hard to see, but they were mounting the tires here. I've taken such good care of them and since they have no corrosion on the face whatsoever, the bead area also had no corrosion. They just had to wipe them off and start mounting the new. Michelin LTX M/S2 LT265/75/R16E. My only complaint here is that they only inflated them to between 55.0 and 55.5 PSI instead of the 65 PSI as requested by me and added to the work order. I have to inflate these up yet as well as clean the spot on the rim where the old weights were, but it's too cold outside tonight to do that this evening.
They had to mount special 8-lug adapters to them in order to balance. Had to install with an impact.
Here, the tech is executing computer balancing for all four tire/wheel combos. I was very impressed here. They not only balanced each one to perfection (.000 on both sides of each wheel), the tech also scrubbed off the blue coating from the white lettering.
The new Michelins finally installed!
Moving over for a free included alignment check. Alignment checked out just fine and required no further work.
Finally done, just after 18:00. After they pulled it up, I reinstalled the center caps and exchanged the plain valve stem caps with the Ford OEM ones. These tires just look amazing and are so quiet! I know Belle was glad to get rid of me since I was constantly asking questions and wanting to go out in the shop (which required an escort).
The tire tag:
Jon
Oh well, I stared at all of them through the window and most of the work was done close to the window, so I didn't really miss out on too much.
I agree about the blue letters. I haven't seen many on the road with the blue left, but I didn't know what they'd do. That Blazer in the foreground in some of the pictures got the white letters in and they didn't clean them off on there.
Just wait till the 16 yr old needs something to drive.
BTW, I have the same tires on my EX, very happy with them so far. Also have the same on my Chevy pickup.
