Windsheild Wiper Problem
Old Dec 10, 2011 | 05:03 PM
acbrown41's Avatar
acbrown41
Smile Windsheild Wiper Problem
yea i have a 1980 Ford F-150 Ranger 4x4 302 5.0L V8 4 spd manual. been working on it for a few weeks now and getting it road ready. went to see if the windsheild wipers worked and they dont. i looked in the owners manual at the fuse box diagram and the fuse is gone but you can press in the **** and it will run the pump for fluid but if u turn it the wipers wont come on. do i have a bad motor? or what do i do. please leave some tips or hints to help, thanks!!
Old Dec 10, 2011 | 05:33 PM
81ChopTop's Avatar
81ChopTop
Edit: First reply got mixed up.
Try replacing the missing fuse. If it blows, you need to start looking for a short, bad connector or different motor.
Power in: Black/Lt Grn
From switch to motor:White, Red, Dk Blue/Orange, Black/Pink
Ground on motor: Black
Output to washer motor: Black/White
Old Dec 11, 2011 | 07:22 AM
Franklin2's Avatar
Franklin2
The motor also has a hot wire(with the key on) going directly to it. When you turn the dash switch off, the motor uses the other power source to keep going till they get to the park position.
Old Dec 11, 2011 | 09:50 AM
ctubutis's Avatar
ctubutis
See if this helps you:
https://www.ford-trucks.com/forums/1...g-82-f100.html
Old Dec 11, 2011 | 02:47 PM
acbrown41's Avatar
acbrown41
there is a spot for a fuse but when you go to put the fuse in its spot it wont stay, the prongs are gone to hold the fuse as if a fuse was never ment to be there, but in the owners manual it tells me in runs the winsheild wipers and winshield washer, but there is no fuse in it now and it will still run the windseild fluid out, kinda weird without a fuse being in there to power it, so im not sure if maybe the switch could be bad or is that even possible in that truck, ive never had that happen on my past 80 series fords so im confused
99Ethan7.3
Aug 14, 2018 10:43 PM
Rogue_Wulff
27
Dec 18, 2016 08:59 AM
GloveGuy
Electrical Systems/Wiring
Dec 21, 2007 09:22 AM
Cannon51
Feb 28, 2007 10:36 PM
mudman241
Sep 14, 2001 10:06 PM
