just bought an 2005 6.0 and it had a bully dog tuner in it. The tuner is gone but it still had two egt probes in it. My question is will the probes work on any other gauges other than bully dog?? I got a sct livewire coming and i know they won't work on it but if anyone knows I would appreciate the help. Thanks. It is a
<center></center>
Enlarge
<center></center>
<table class="vi-is1" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td colspan="4">Bully Dog 40390 Pyrometer Probe Kit EGT Exhaust Gas
Just order the new probe, remove the old and screw in the new one and you are good. Often they die after a while anyway. You might even try connecting first as often they work on anything but probably better to have the new on. I would use the pre turbo. Don't take out one and tleave a hole, better not to touch the one you are not using to keep the seal in the pipe good.
Yes the wires are there. Pretty much what is in the pic is what I got plus a one. and i do not have a new coming with the new programmer as of yet unless these will work somehow.
