92 f150 cruise control
Is your transmission acting up, too? If so, it's probably the ABS sensor in the rear end being covered with metal filing & not picking up the signal any more. This indicates more serious problems in the axle, so don't JUST clean it off...
Do you have ANY nonstandard wiring in the truck? (stereo, alarm, keyless entry, remote start, lights, CB)
The servo is under the hood by the L hinge and it has a cable that's supposed to be attached to the throttle cable under the semi-round black plastic cover on top of the throttle body. Make sure it hasn't popped off.
