New heated seats installed in my 99 F-250
I just got done swapping the seats in my 1999 F-250 extended cab. I have a Lariat but the seats I had were very neglected from the previous owner and looked bad and I happened to find a set of heated and powered front seats from a 2006 F-350 at a junk yard close to home. The seats look brand new and I scored them and all electrical connectors for 200 bucks! I had a power driver seat all ready but no heat and the passenger side was all manual. Here in MT in the warm winter climate we live in, leather seats need heaters as standard equipment!
The swap was easy, the seats bolts right in and I had to re-wire the driver seat harness to add the wires for the heaters and I had to make my own harness for the passenger side. I have the factory service manuals so I had access to wire schmetic which made the wiring a piece of cake.
While I was there I scored the lower plastic panel on the ash where the cup holders are and it has the factory Ford trailer brake controller and I got new cup holders. MY cup holders were broken and my panel was also chewed up from the previous owner drilling hole to mount stuff. I know the color is not exactly right but it looks way better than what I had before.
I am on the search for a center console so I can take the middle jump seat out all together.
Here are some pictures of everything.
Jeff
Before--------
After---------
Jeff
Before--------
After---------
Do you have a good source for the factory service manuals you mentioned? I have a 2001 F250 Platinum, but it didn't come with heated seats either. I've purchased all the 'parts' to make them heated, but the harness inside the seat doesn't mate up with the one coming out of the floor. Any help would be greatly appreciated.
If your pickup is like mine there is a connector on the floor under the seat that has three wires. One is hot all the time, one is ground and one is for the seat belt indicator in the dash. It is a connector that can have 4 wires but only three are used. The new connector for the heated seats on the driver side has spots for 8 wires but only use 6 so the three additonal wires are as followed. One is hot all the time, one is keyed power and the other just runs over to the passenger seat to provide a power source there.
On the passenger side it is a connector with 4 spots but only uses 3 wires, and one comes from the driver side seat, one is ground and one is hot all the time.
Driver seat heat wires:
Light blue/pink is keyed power.
Red/black is hot all the time.
White/red runs over to the passenger seat.
Driver side power movement wires:
Dark green is hot all the time.
Black is ground.
Brown/ light blue is the seat belt indicator.
Passenger side heat and power movement wires:
Black/white is hot all the time for power movement.
Black is ground.
White/red is from driver seat to provide power for heated seats.
Hopefully that will help you out.
Jeff
Very nice!!! Do I understand that the heaters are "always on" (with key-on)? I didn't see a switch and you didn't mention one (unless I missed it).
On a more important note, you got me all excited when I saw that factory brake controller from the 2005+!!! I checked, though, and saw your post where you asked about wiring it in. If you figure that out be SURE to document it b/c there are a LOT of people on here - myself included - that would love to do that!!!
Also, is that another glove-box under that IBC? My '02 doesn't have anything there.
There are switches on the seat to turn the heaters on and off, but they do not turn off until you turn the switch off. If the switch is on and the key is on then there is heat.
As for the brake controller, I looked and since my 99 doesnt have a CAN bus electrical system like the 2005 plus so I am missing data to make the controller work. I am just going to bag that project and put an aftermarket one in the place where the factory one is. I am not sure if the controller will work with out that and I am not sure I want to try it with out it.
That is another glove box as that panel with trailer brake came from a 2006 pickup. I had to drill some new holes but other wise the panel fit in place of my old piece.
Jeff
Jeff
Jeff
My seats came out of a 2005 or 2006 I forget now which year but they bolted right in with no modifications, all I had to do was a little bit of wiring and then done. As you can see in one photo the newer tan seats do not match the color of the old which is clear by my center console seat, but I am going to change that out later. I should have bought the middle seat when I got the others but oh well.
Jeff
I'm currently working putting '06 seats in to replace my '03 heated, powered seats. I want the continuous heat rather than the current cuts off after about 5 minutes models. Did I understand correctly that when you turn the seats on you can't turn them back off with switch and have to wait until the key turns off? Any special problems that you can think of that I might run into that are different from your project? Thanks in advance.
The seats bolt right in and all you have to do is a little wiring. Since your 03 had heated at least on the driver side it might have the same connector and it would be a plug and play setup. Im not sure if you have heated passenger seats, they were only offered on crew cab models but there is only three wires to run for it and you are done.
Jeff
I'm going to throw this out there not knowing what the wiring looks like on the new brake controller, but at least on my e99 there are 2 different style wiring harnesses for the brake controller. One is plug and play to an aftermarket brake controller, and the other group of wires have nothing on the ends, just laying there. Can't you take the factory plug and harness on the new brake controller and splice them to the 99 factory wiring. Just a guess but i'm sure the wires are the same color codes.
