I wanted to start a thread about aftermarket cams.
What you have used and what you liked about them.
The only two that I have heard of is typefour and delta are there more.
What cam have you used with a turbo and what rpms was your peak boost.
The reason I am checking is, this spring or summer I need to build a new idi and want to build it to get it's peak torque at a low rpm, generally peak torque and peak boost runs together.
What has been your experience.
What rpm do you get your peak manifold pressure at. Did they give you any rpm specs with it,as in where the best power range is at.
I want to go bassackwards than most people, as in less rpm's.
then you need my torque cam, brings in boos 100rpm lower and starts pulling hard an 1200
