BRAKE PADS?
Old Dec 9, 2011 | 07:15 PM
K80's Avatar
K80
BRAKE PADS?
Any recomendations about what Brake pads to used for a 2005 PSD; standard, semi-metalic, ceramic, etc. Thanks, Mike
Old Dec 9, 2011 | 07:19 PM
Snuggyworm's Avatar
Snuggyworm
the motorcraft brake pads. cant go wrong wif them. do a google search and u'll find part #s and jus pick the cheapest price for the motorcraft brake pads. best of luck!
Old Dec 9, 2011 | 07:25 PM
BLADE35's Avatar
BLADE35
X2 here
I got 75k out of them
Old Dec 9, 2011 | 07:43 PM
Tampa250's Avatar
Tampa250
I'm at 96k on my ORIGINAL front and rear pads! Whenever they give out I will be buying OEM.
Old Dec 9, 2011 | 08:39 PM
Hank85713's Avatar
Hank85713
anybody tried the hawke or ebc brands and rotors? Ive seen them advertised and in reality the OEM are pretty lame.
Old Dec 9, 2011 | 10:28 PM
Snuggyworm's Avatar
Snuggyworm
heard bout them. not many i've heard tat are used on our trucks. most go wif motorcraft cos they're pretty good. i jus replaced my rear ones at about 96k. mine's a dually so heck, i aint taking no dang chances at slippin up. somebody might get killed if i'm irresponsible about keeping up to date on my brake pads. lol.
Old Dec 9, 2011 | 10:51 PM
K80's Avatar
K80
BRAKE PADS
I was considering Hawk brand pads: very expensive pads, front and rear around the $170 range. Will stick with reply suggestions; Motorcraft OEM. Thanks, Mike
Old Dec 9, 2011 | 11:01 PM
Snuggyworm's Avatar
Snuggyworm
ur welcome mike. have a great weekend!
Old Dec 10, 2011 | 04:12 AM
npccpartsman's Avatar
npccpartsman
X2. I got 108K from my first set of front OEM and replaced them with Premium motorcraft pads. At 178K I still have over half of them left. I've never replaced the rear pads (yet). And FWIW.......no dust or squealing.
Old Dec 10, 2011 | 06:22 AM
Tampa250's Avatar
Tampa250
Out of curiosity, how were your front rotors when the pads finally went on you? I'm just wondering if these OEM pads are rotor killers or not. Were you still above minimum spec on rotor thickness or did you have to replace them?
Old Dec 10, 2011 | 06:25 AM
npccpartsman
I was way above minimum specs. I had them trued up but it didn't take much at all. Still on the stock rotors at 178K and would be surprised if they couldn't go one more time.
Old Dec 10, 2011 | 06:27 AM
Tampa250's Avatar
Tampa250
Wow- good to know. I'm pretty impressed with the stock braking system components.
Old Dec 10, 2011 | 10:03 PM
FSeybert's Avatar
FSeybert
The Hawk LT pads are awesome. Vastly better stopping power than stock. I lost a set of rotors pulling a large fifth wheel and had to panic stop on a steep mountain. Replaced with Cryo-Slots and Hawk LT pads. I now have over 100,000 on them and they are barely wearing. The stock pads rotors were fine for an empty truck, but the Hawk and Cry-Slot set up really helps with the heavy loads.
Matthewyfz
May 10, 2019 08:53 AM
khendrix
2004 - 2008 F150
Aug 12, 2004 11:51 PM
