heated mirrors
Old Dec 9, 2011 | 06:59 PM
noal133's Avatar
noal133
heated mirrors
Has anyone here added heated side mirrors to their truck ? what did you use ? any aftermarket or retrofit ? this looks like the place to get some great ideas.
Old Dec 10, 2011 | 07:05 AM
Franklin2's Avatar
Franklin2
I thought I saw a ad in a magazine where LMC truck sold heated aftermarket mirrors and seat inserts.
Old Dec 10, 2011 | 10:27 AM
noal133's Avatar
noal133
heated mirrors
Thank you for your reply. I found the seat inserts, but could not find the heated mirrors. Does anyone know if the power mirrors for up to 1996 are heated ?
Old Dec 10, 2011 | 10:28 AM
Diesel_Brad's Avatar
Diesel_Brad
No. Ford di not offer heated mirrors in trucks till at least 99
Old Dec 10, 2011 | 10:32 AM
noal133's Avatar
noal133
heated mirrors
Sorry to hear that, I was hoping there was a easy JY swap.
Old Dec 10, 2011 | 11:57 AM
Franklin2's Avatar
Franklin2
I looked at the ad closer, and the retro-heated mirrors they have are for GM trucks.
Old Dec 10, 2011 | 12:17 PM
noal133's Avatar
noal133
heated mirrors
Still might be an option if they would fit the contour of our doors, I have some friends that are GM guys, maybe i can borrow a factory mirror to see if it could be made to fit.
Old Dec 10, 2011 | 03:42 PM
TheKirbyMan's Avatar
TheKirbyMan
You might be able to modify the GM mirror to bolt to the Ford mirror frame, like mount the mirror with part of the little 90 degree "arm" cut off and bolt it somehow to the Ford frame.
Old Dec 10, 2011 | 07:19 PM
Diesel_Brad
Here you go, HEAters FOR mirrors Auto Mirror Heaters 12 vdc 17 watt 240 mm x 114 mm (4) on eBay!
Old Dec 11, 2011 | 07:44 AM
noal133's Avatar
noal133
heated mirrors
Thanks Diesel Brad, I think that is the way to go for me. I used a 89 bronco dash that had rear defrost in my truck so I already have the switch. I think I will get a couple of those and try it.
Old Dec 11, 2011 | 03:46 PM
cadunkle's Avatar
cadunkle
Heated mirrors? You like on the north slope or something? Get real, it's a truck.
Old Dec 11, 2011 | 04:55 PM
noal133's Avatar
noal133
heated mirrors
Its my truck , I can add any thing I want to it .
Old Dec 11, 2011 | 05:00 PM
TheKirbyMan
It's what makes projects fun...you can add things you -want-, even if you don't -need- them.
Old Dec 12, 2011 | 12:22 AM
artfd's Avatar
artfd
Exclamation
Hmm. I've got 2 heat guns and a 2200W generator...
michael a
1947 and Older Ford Trucks
Aug 19, 2015 07:10 PM
medic7909
Dec 28, 2006 08:37 PM
roaky81
Mar 7, 2006 02:30 PM
97F250XLT
Jun 5, 2005 01:04 PM
