hpop line?
Old Dec 9, 2011 | 11:29 AM
PowerstrokeRyan's Avatar
PowerstrokeRyan
hpop line?
Coming home from school droped the gf off at her house and being the gentleman i am i pull into her driveway and walk he up. Well as i was backing up noticed a bigger than usual oil stain and got out and looked. There was oil over the driver fender steering shaft and drive shaft. Not turbo or oil filter (was just replaced) is there a hpop line in that direction? Thanks guy any info would be great. Have a big snowmobiling trip next week would love to have it fixed by then.
Old Dec 9, 2011 | 11:30 AM
PowerstrokeRyan
Ill try to get some pictures up tonight if i have tis have to help mom clean house for party tom so it might not be till later tonight.
Old Dec 9, 2011 | 11:41 AM
Brown Falcon's Avatar
Brown Falcon
Wasn't from the oil cooler was it?
If it is from a HPOP line it's probably a busted o-ring. Easy to replace.
Old Dec 9, 2011 | 11:54 AM
PowerstrokeRyan
I didnt get a great lookat it i just cleaned it off with brake cleaner and engine brite and im going to start it when i get home in two hours to see where it is.where os the oil cooler? And it never did this until i plugged in my truck the night before.
Old Dec 9, 2011 | 12:36 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Also could be leaking oil from the BIG bolt in the front of the head, but more common from a bad o-ring as mentioned.
Old Dec 9, 2011 | 10:06 PM
oldbird1965's Avatar
oldbird1965
If you just pluged in your cooler for the first time it just might be your oil cooler.
Old Dec 9, 2011 | 10:12 PM
Brown Falcon
Oil cooler is the big tube looking thing that runs from where the oil filter goes on forward to the front of the block.
Your block heater plugs into the back end of it. Very common for the o-rings in that to go bad during cold weather.
brandonkinney
Mar 1, 2015 09:21 AM
timmytoes
Apr 24, 2012 10:50 AM
Hiflyer746
Apr 6, 2007 07:29 PM
psandico
Jul 14, 2003 11:09 AM
