Keepin it Cool
I wish I could say this was the first time my truck got a little warm. Almost every car show I go to, there is a line...and the truck gets a little heated. Frankly, it's annoying. I was hoping to nip some of this issue in the bud this winter so I can idle for more than 5 minutes without overheating. I know people are running more radical setups than I am...what are you using for a radiator? It has become obvious to me that a stock radiator will not do what I need it to do.
I got a mild 289, stock F-1 radiator, stock 289 water pump, stock radiator cap (came with the truck), stock thermostat temp (195), timing is static at 10 advanced, plugs are tan so the air/fuel ratio isn't too far off one way or the other, 16" or so electric puller fan set to come on at 160 degrees or so. And before anyone mentions it, no I have no intention to put in a 160 degree thermostat. That does not fix the problem, it just opens things up faster. What I am thinking is there is not enough pressure in the system. I already had to patch a few veins, so putting a higher pressure cap on the stock radiator would probably blow the tanks or my repairs which is why I wanted to know if anyone has found an affordable aluminum radiator that fits these trucks. Because of where I mounted my engine I will probably have to switch to pusher fans unless it is thinner than a stock F-1 radiator.
I had the same problem in my son's 66 Mustang with a 302. We ended up putting in an aluminum radiator. It has two rows of really wide tubes. The manufacturer says it's the same as putting in a 4 row brass radiator. It did solve the heating problems. The bulk of the problem was at long signal lights when there just wasn't enough air going through the radiator.
On my 52 F1 project, I put in a 2 row aluminum radiator from Superior Radiator in Michigan (he's an ebay seller too). I haven't driven it yet, but I did get it started (by the way...."it" is a 351W, so not a lot different than your 289). I don't have a fan yet, so on the cam break in run it did warm up to 220 before I shut it off. I put a box fan in front of the radiator & re-started the engine....it settles in at 180 degrees which is what the thermostat is. So...good cooling without a lot of air flow.
It could be that you just need a little more cooling capacity for things like shows and anytime you're idling for a long time.
Here's a pic....the radiator fits the stock mount and has hose outlets for the small block Ford.
I would look into resolving the electrical issues, make sure you have enough battery and battery repletishment power to run the fan at speed at all times, all conditions.
Look at your fan. Is it large enough? does it have a shroud that flows air through the entire face of the radiator?
Air flow at road speed pretty much eliminates the need for a fan. Many years ago I ran a mild 1952 Merc with a flathead without a fan for a long time, just made it a point not to get stuck in traffic. It was a challenge that I set for myself.
So check airflow and make sure your battery is staying powered enough to run fan.
JMO and good luck.
Also, to clarify, my electrical issue is a stuck circuit that drains the battery if I leave the battery connected without running the truck over a period of months. I am currently working on tracking that circuit...which shouldn't take too long. All the wiring, battery, alternator...they are all good, brand new, and regularly tested to make sure they are good. I really think my problem is insufficent ground somewhere. Honestly a non issue when dealing with cooling. If it was a huge electrical draw or something like that I would focus my attention on that first cause the two issues could easily be related. I also can clearly see my fan when at a stop light to know it is working. I have no shroud, just an electric puller fan. It's not the highest rated fan as far as CFM...but it should be enough. It's not like I am running some super hopped up big block.
When I am cruising at any speed the temp sits between 195 and 200...which I am good with cause I am running a 195 thermostat. I too have put myself to the test of keeping it moving to keep it cool which works great 90% of the time. I am just getting burned out on lapping blocks to get a short line somewhere. I can't fit more fan on the radiator...it's a very tight fit as it is. And there is no shroud.
That's a slick radiator Old Dan. I may have to look into something like that. I am not so sure the capacity is my problem...I really think it is pressure related. I think if I were able to run an 8-12lb cap that my cooling problem would be solved. As it is, the cap I am running is a 4lb cap when it was new some 20 years ago. It was old and weathered when I got the truck almost 10 years ago. Every pound counts.
What I was looking for is a radiator that is slightly thinner and shorter than stock. The reason being is I would like to put a dual puller fan unit on it which would facilitate a shroud and give me more CFM of air pulling through the radiator, and facilitate a higher pressure rating for a 12lb cap. The catch is it needs to be thinner than stock to give me room for the fans.
It sounds to me like you simply don't have enough proper air flow at low speeds. You say everything is fine when driving and air is moving, but not so much at slow speeds or stopped/idling. I would look at a different fan setup, personally. Are you committed to the electric for some reason? Could you try a conventional fan and see if that makes a difference? Sometimes electrics aren't all they're cracked up to be.
A thought on fan clearance. There are two spots for the radiator support/fender supports. You might be able to mount the support in the front set of holes for more clearance for your fan.
I'm a little concerned about that....I have the radiator support put in the forward set of mounting holes & my water pump pulley is pretty close to the radiator...I'm not sure if I can get a fan in there or not. The stock F150 unit that came with my engine has a long clutch on it, so that's out. I was planning to go with some electric setup. I'm not all that fond of flex fans. The good news is that while the engine is static, it heats up...when I put the box fan there...it has basically minimal airflow and the temp gauge snaps right to the thermostat rated 180 degrees.
All that being said...Fordman's problem could be twofold...not enough air, and maybe the radiator isn't up to snuff.
Dan
52 Merc...I was under the impression that too little pressure can lead to mild overheating issues. I knew that stock 289's ran with about 4lbs or so, later they moved to 8lbs. The 302 ran with anywhere from 4lbs to 12lbs towards the end of their run in the 90's. There has been a steady increase in stock cooling system pressures, I always figured there was more behind it than just boiling point. The other Fords I have built or been involved with building always ran 12lb caps with stock or stock replacement radiators (OE or aluminum)...never had a problem no matter how radical the setup was. I also know that (at the time) I was reading 220...and I was boiling.
Old Dan, I think you may be 100% correct. This may be a two part problem with a two part solution. Lack of air, and bad/worn radiator. I do know that my radiator has 3 broken and sealed core veins (they were leaking), it has god only knows how many that are plugged, I ran pepper and radiator stop leak through it to help seal the repairs. Long story short...my radiator has seen better days. The fan only pulls through the top half of the radiator because of how close it is to the water pump. Perhaps moving the radiator forward and installing a second fan would help? Or using a stock fan? While I am not against getting a good direct fit aluminum radiator such as yours...I highly doubt I can afford that at this time. I was more or less hoping to find something a little more affordable on a shoe string buget. I don't want to get an inferior product (or a Chinese product), but something that works well that's in my wheel house. Something like a stock radiator (for x or y car) that fits the hole...something along those lines. I hate to sound like a cheap ***, but in times like these...there is not much I can do to help it right now. If there is no other option, perhaps shelving it while I save some cash is best.
I think I am going to try to keep my current radiator for now. Any repairs or modifications done to the truck will facilitate the stock radiator. I am going to move it forward and see if I can't gain enough room for a second puller fan. If so, we will see how that handles it. I am sure doubling the air flow won't hurt! If it helps or even solves the problem, I will give the system a flush and top off with a good 50/50 mix and away I go. Otherwise a new radiator is in my future.
To cool and engine you need coolant flow and air flow and it does sound like you probably have a marginal flow on both.
I am very much so interested in this Dodge radiator that people have been using. I would like to give that a whirl with dual fans or...if it will fit...a stock fan and shroud of some sort.
EDIT: I just looked on my build sheet, it was for a 1975 Dodge truck. Sorry I didn't put a part number down.
