Help, possible IDM failure?
Old Dec 10, 2011 | 03:25 PM
Robert6401's Avatar
Robert6401
So, was it just a loose UVCH? Or did you swap IDMs also?
Old Dec 10, 2011 | 03:30 PM
KJNDIVER's Avatar
KJNDIVER
Truck is running good again. Now i know how to do it for my truck. Another job solved by the brotherhood. Thank again guys.
KJNDIVER's Avatar
KJNDIVER
Just loose harness
Old Dec 10, 2011 | 03:36 PM
nlemerise's Avatar
nlemerise
You are a GOOD son! A credit to your father .
Old Dec 10, 2011 | 03:37 PM
PaysonPSD's Avatar
PaysonPSD
"Just loose harness"
Glad to hear it.
Old Dec 10, 2011 | 07:36 PM
KJNDIVER's Avatar
KJNDIVER
Ok guys, now that im back at a computer and not using my phone ill give a bit more what i found. I found that I need a better meter. I was using an analog meter that was an el cheapo. When i check the pins first and got a 0 reading, same as if i touch the leads together i figured it was still making good contact. When i checked the other side and got no reading (eg. open contact) i knew that side had to be loose. Which it was, dang near all the way off.
As I found it:
Put the aforemention pieces of defiled US currency in their spots and it was all good.
But I did find some other things out about this truck. It appears that the factory stock airbox is to be short lived by evidence of what i saw here.
I have an extra 6637 at my house that will soon be going on this ride. For the time being we will run this wheel until it can be changed. I do not see a problem with this unless someone can convince me otherwise. Also, what turbo housing did the '99 come with? I ask because I saw on the side of the housing, 1.1AR stamped into it. Mine does not have this stamping. And I cant recall which is better, higher than 1 or lower than 1 aspect ratio. After market housing?
I also noticed that the IC was all aluminum. Looked at mine and it has plastic end caps and pipes. This one is all aluminum everything and it looks like the mounting tabs had to be "modified" to get them to fit. Im thinking aftermarket IC as well. Should have taken a pic.
But i did find something else, again, I havent dealt with this personnally as my truck runs like a top (knock on wood) but this appears to be the leaking o-rings ive heard about on the hpop lines. Looks to have been leaking for a while. I dont think its a bad leak, just that its been going on for sometime. Some of the oil around the fitting is gelled up and old, as well as down in the valley, but some is new as well. Just a mess. Is this just an oring change or would it be better to change out the hoses all together?
Does anyone know anything about exhaust breaks? This truck has one installed but cant seem to make it work. Flip the switch and can tell no difference. It is a PacBrake Engine Brake. I havent looked thru the manual yet so i will have to get that from him to read. Hell, he should just drop the truck off to me for a week or more so I can find out all the upgrades and aftermarket stuff the previous owner put on this fine ride.
82caddy
Mar 28, 2017 08:52 PM
awsmev
Nov 14, 2014 12:03 PM
Mazookie
Mar 25, 2014 02:21 PM
PEI
28
Feb 29, 2012 07:06 PM
cavenhedges
Mar 22, 2009 06:31 PM
