Loading question on a 96 f250
Old Dec 8, 2011 | 04:47 PM
yfz 450's Avatar
yfz 450
I have a 96 f250 this sat. I have a job where I need to pick up 25 bags of cement about 2000 lbs and another 5 bags of gravel 250 lbs is this to much weight for one load or can the truck handle this weight. The truck has the 351
Old Dec 8, 2011 | 04:57 PM
thechief66's Avatar
thechief66
A lot will depend on how the truck is set up. I know if I put 3K lbs in my 96 the axle would be hitting the frame. My 92 had heavier springs in an otherwise identical truck.
Old Dec 8, 2011 | 05:10 PM
bobbyjo9's Avatar
bobbyjo9
^^+1 Its not about the motor, it's the stability and brakes more than anything. Ive taken a 4300lb payload in mine and didnt go over 50mph. Your ~2200lb payload should be fine but remember the truck will react quite different.
Old Dec 8, 2011 | 05:11 PM
Diesel_Brad's Avatar
Diesel_Brad
2500lbs is alot for a F250. If you do it, put it all the forward in the bed so it is not all on the rear springs
Old Dec 8, 2011 | 05:16 PM
danr1's Avatar
danr1
That truck should carry that load easy. I carry loads like that and heaver at the tail gate, simply sat in the truck with a hi lo on a skid.
That would be for short distances though, for example 40 - 80lbs bags of salt on a skid 15 miles to kent city. having hi lo driver push the skid as far forward as he can with a empty skid on the forks after setting in the bed.
If you want to load it correctly, and or travel any kinda distance stack that load as far forward as you can.
Stack the bags directly behind the cab, keeping the bulk of it forward of the rear axle.
Old Dec 8, 2011 | 05:32 PM
yfz 450's Avatar
yfz 450
The job is about 5 miles at most from the lumber yard so not to far of a trip
Old Dec 8, 2011 | 05:41 PM
andym's Avatar
andym
No one in this thread seems to be good at math, 2000 + 5 * 250 = 3250.
I think you'll be fine, especially for such a short distance. I would do it and not even worry about it.
FORDF250HDXLT's Avatar
FORDF250HDXLT
then just make it two loads.
when im hauling i look at it like this;
can i fit it all in the bed anyway?
if i can,would it save time and $ anyway?
if the distance is short,i won't think twice.i make it two trips.
if it's an hour or more away,that's a lot of time and $ saved if i can get her on and still be safe of course for the setup, if i don't have to go back to get another load.
if the distance is just a 5 mile trip,there is no purpose really trying to haul more than your setup for.that kind of weight makes the vacuum brakes crappy.not really unsafe yet i suppose,but not fun either.
Old Dec 8, 2011 | 06:14 PM
danr1's Avatar
danr1
I didn't see where anyone did any math, maybe I missed it?
I read it as 25 80# bags plus 5 bags of gravel that total 250#?
Bags of cement commonly weigh 80# so 25 of them would weigh 2K.
The bags of gravel must weigh 50# which again would be common for straight gravel however OP didn't say, just gestimating total weight of those 5 bags.
Gives em a total weight of 2250 and easily handled by a F-250. More then enough frame, spring, axle and brakes.
Trunk has a GVWR of 8600 (if hd), truck weighs around 5500lbs (4x4) leaving 3100lbs of payload ("payload" includes people and fuel etc etc). That is going by the book, everyone one knows they'll carry more then the rating.
Heck I'd haul that load with a F-150 if I had one, wouldn't give it a second thought. I would however place the load forward in one of those!
Old Dec 8, 2011 | 06:23 PM
andym's Avatar
andym
I read it as 5 bags of gravel weighing 250 lbs each... now that I think about it that's a pretty heavy bag of gravel.
Old Dec 8, 2011 | 06:33 PM
danr1's Avatar
danr1
Yea it would, and gotta say I'd be afraid of em even if like that!
Old Dec 8, 2011 | 06:34 PM
bruno2's Avatar
bruno2
Thats not even a big load for the truck. I wouldnt even think twice about it.
Old Dec 8, 2011 | 09:06 PM
toby tough's Avatar
toby tough
Any respectable yumber lard would deliver it for you. I've hauled loads like that in my other trucks b4. You should have no problems.
RJL1
16
Apr 19, 2017 05:53 AM
senix
Oct 27, 2008 04:16 PM
walcoffl
May 29, 2006 09:13 PM
71_4x4_390
Apr 23, 2004 08:40 AM
Big Red F250 SD
Jun 17, 2003 01:10 PM
