New pipes
Old Dec 7, 2011 | 07:15 PM
blkF250HD's Avatar
blkF250HD
Thumbs up New pipes
I've had some polished SS Magnaflow tips laying in my garage for a while, and finally decided to put them to good use. A few hours after work with some scrap pipe, the bender and welder (I work at CarX), and another guy and myself built this:
I previously had a stock-exit with some polished square tips. It didn't look bad, but it was fairly loud in the cab (drone wise) and it had a higher pitched sound (2.25" pipe). New system is still 2.25", but the tips are 2.75" IIRC. Result is a deeper, smoother sound, and less interior noise- we purposely extended them past the bumper for this reason. Still have the 70 Series on it along with no cat.
FWIW- the truck isn't tilted, it's a camera phone picture.
Also- For those of you with stainless tips that are getting corrosion, pick up some 1000 grit and 3000 grit sand paper. Use a sanding sponge behind it (I used an old headlight refinishing kit) and begin wet sanding them. Good stainless will come back, and can be re-polished with higher grit paper and some compound.
06F150Guy
2004 - 2008 F150
Dec 29, 2010 08:36 PM
AspenF150
2004 - 2008 F150
Sep 7, 2010 07:19 PM
stack1212
Exhaust Systems
Dec 28, 2008 11:21 PM
metal83
Exhaust Systems
Oct 3, 2008 12:47 PM
88grandmarquis
Exhaust Systems
Apr 2, 2004 02:42 PM
