From what I have seen(I haven't seen everything) the looped cooler lines mounted on the front crossmember are standard on every truck. They commonly rust out and get bypassed, but I believe they are standard. I thought you guys were talking about a larger more official cooler that was a option. I have never seen one, and was waiting to see if one actually existed for these trucks.
When my stock cooler rusted out, I was contemplating adding a cooler, like a tranny cooler, to the power steering system, but I didn't know where to mount it. If you look at what you have now, the reservoir on the pump is the highest part in the system, where air will migrate and escape. I thought if I mounted another cooler up high out of harms way, it would trap air in the system and make it noisier than it already is.
However, my crossmember has absolutely no sign of ever having cooling line running along it. So I think what I have may be factory. All I need is for another person who doesn't have the power steering cooler option to chime in and post a picture to compare and see if the lines are routed and bent the same way, just as long as the other member's lines are original as well.
You may have to dig the crud off the front of the crossmember, but see if you have a couple of small threaded holes in different spots. These are where the screws go for the clamps that hold the looped line assembly in place.
Already have, the only one I have is inside of a hole in the driver's side axle pivot bracket. I'm not sure, but I think that may be one of them.
Both have a cooler of sorts in the metal return line .
The standard one is a shorter metal line with just a single loop that is circular bolted to the crossmember on the drivers side.
The Power steering cooler option, the metal line is twice as long and the loop is oval in shape and goes the entire length of the crossmember before coming back to the pump.
Kind of hard to describe in words, but the coolers are a part of the return line. Buying it from Ford you would replace the return line to get either the one with, or without the optional cooler.
Napa sells these as complete units. Autozone makes you "build your own".
The standard one you described is exactly what I have, so it must be original.
As long as the ones from Napa are made to OEM specs, then I will probably go with them.
What would happen if you just teed into the tranny lines running to the cooler? They both use the same fluid and they are both on the suction/low pressure side of things so it wouldnt effect the pressure of the operating portions. Could this be done or would have a negative effect?
How are you going to keep the steering pump reservoir full like that? You would have to put the suction line coming out of the tranny pan and get rid of the original reservoir all together.
Here is mine, you can see the two screws holding it to the cross member:
That is very different from what mine had. Mine was a simple piece of tubing that went across the front lower portion of the crossmember, did a 180, and went right back where it came from. Also appears to be a bit larger diameter tubing than what was under my truck......
