Sponsored by: Real Truck
wont start
Old Dec 7, 2011 | 11:31 AM
boardbender's Avatar
boardbender
wont start
2001 F350 V10 cranks over but does not fire. I put some starting fluid in to check if it is a fuel problem or ignition. It did not fire. It does not throw any codes. Hopefully someone has an answer.
Old Dec 7, 2011 | 12:14 PM
senix's Avatar
senix
try the fuel cutoff switch? all fuses?
Old Dec 7, 2011 | 12:37 PM
boardbender
wont start
it did this a couple weeks ago. I let it set for few hours and rhen it started. It started fine for the next six days and now doing again. Thats why I dont believe its fuses. Would fuel switch work intermitely?
Old Dec 7, 2011 | 01:35 PM
senix's Avatar
senix
no...sounds like a wiring issue if this happened before..or maybe a starter issue.
If you have all electrical working try tapping on the starter and see what happens.
Maybe a flat spot on it.
Old Dec 10, 2011 | 07:15 PM
carlsson's Avatar
carlsson
Same problem here
Sounds just like my F250. It runs great when it starts, but a few times in the last couple weeks it has a hard time firing and starting to run. Never done this in the first 130k miles. Starter turns engine over fine, but sometimes doesn't fire at all or runs @200 rpm then stalls, or it runs perfectly, and has not triggered Check Engine Light. I have gotten so used to starting vehicles without pressing gas pedal, but the last time it happened I tried that and it started. I would really like to hear what your problem turns out to be, so please post if you solve it.
mkbuth
Apr 15, 2018 03:06 PM
gordo777
2004 - 2008 F150
13
Apr 13, 2015 07:42 PM
700kid
6.4L Power Stroke Diesel
17
Jul 15, 2013 10:05 PM
ju015dd
Apr 16, 2011 10:12 PM
Marting
2004 - 2008 F150
Dec 8, 2010 06:49 PM
