thanks for the info i had looked at those instr. several times at clays site. what is the best way to plug the hole in the tube and do i need to remove the part that is inside the tube would like to see those pics chris thanks
I used a carriage bolt, but a freeze plug would work best.
I know the large o-rings are 1-1/4" ID x 1-1/2" OD, Can't remember the ones on the screws. Just take one of the small ones with you and match it up. Look in the plumbing section at your local hardware store.
IH also has them.
Crankcase Breather O-Rings
(Ford) F4TZ-6769-A (small; seals screw head)
(Ford) F4TZ-6769-C (large; seals breather adapter to valve cover)
(International) 1824452C2 (large; seals breather adapter to valve cover)
(International) 1820784C2 (small; seals screw head)
Regular (not OEM) large o-rings are 1.25" ID and 1.5" OD
Originally Posted by Chris56ford
Just to add another idea.
I have mine vented right next to my 6637 filter. I used 3/4 heater hose and ran it to the filter where I tied it to the filter mesh. I attached a cheap Mr. Gasket valve cover breather to the end at the 6637. The intake still sucks the fumes right through the filter so no fume smell in the cab and I don't have any oil messes.
Been running it for about 1500 miles now with no problems. I can get pictures if anyone wants, its not the prettiest but that wasn't what I was going for.
I did a temporary CCV mod last spring after installing my stage 1 injectors (and took some pics) not very pretty but it works and I haven't really seen a need to change it yet. I haven't noticed the bad smell or smoke or much vapor venting.
I turned the dog house around to vent toward the firewall then I removed the original rubber 90* and slipped on a short length of 3/4 in. black poly pipe used for irrigation or sprinklers systems.
Then I added 3/4 in. poly 90*
Then about a 2 ft. length of 3/4 poly.
You can see where it ends and vents down by the frame. There is just a little evidence of oil on the tube and frame. I may fasten or hang a small plastic bottle at the end of the tube to collect the oil just to see how much I collect, I have not noticed oil dripping from it or spots in the driveway. This was super simple and gets the oil out of the intake.
I am not suggesting this way of modding the ccv just sharing information IDK
That's how I have mine also Rich. Little different, but more/less the same. Some route the hose over the booster so oil can drain back down it into the vc if they have oil dripping. Mine looks just like yours.
I still like the idea of running a pipe forward, then a tee, and branch it off to outlet above the two points on the radiator core support where it mounts to the frame. Constant spray of oil, they'll never rust....
